Topic: Measurement of Bandgap voltage (Read 55456 times) previous topic - next topic
retrolefty
#15
Jan 15, 2011, 09:01 pm Last Edit: Jan 15, 2011, 09:03 pm by retrolefty Reason: 1
Cool, something to play with tonight.
So is the purpose of this so that the A/D conversion is performed in a quieter condition then normal non-sleeping condition? I have noticed that on the code I've posted that if I perform just one read of the bandgap voltage it has not settled down to a stable count value. Three reads is OK, within a count or two, and four has the same stable count reading that stays the same no matter how long the function continues. I recall reading in the datasheet about having to perform multiple A/D conversions before obtaining a stable reading, but I thought that was only when changing voltage references, which I'm not doing?
Again thanks for posting the code.
Lefty
Coding Badly
#16
Jan 15, 2011, 10:53 pm Last Edit: Apr 08, 2014, 09:24 pm by Coding Badly Reason: 1
Exactly.  I've notice some difference on the ATmega processors.  There seems to be less jitter in the least-significant bit.  I've noticed a huge difference on the ATtiny processors.  The values are rather erratic in "polling mode" but rock solid in "noise reduction mode".
My 168 and 328 processors behave the same way.  The first reading after switching ADMUX to "measure the bandgap" is garbage.
About the same here.  I usually have a short time delay between readings so, in my case, the readings are stable by the third one.
