Topic: processing interfacing (Read 4880 times) previous topic - next topic
prisonerjohn
May 22, 2006, 03:19 am Last Edit: May 22, 2006, 03:22 am by prisonerjohn Reason: 1
Hi again :)
I am now trying to set up a communication between Processing and Arduino.  I created a simple pong game to do this where the paddle is controlled by a potentiometer connected to the board.
This part works really well, but I want to add communication in the other direction too:  I want Processing to send a signal when the paddle is hit, and when the Arduino board receives this signal, it plays a sound on a connected speaker.
How can I tell the Arduino what is incoming and what is outgoing information?
I am attaching the code I've got so far (in the following posts since I'm running out of space), but the speaker element doesn't work.
Thanks for the help!
prisonerjohn
#1
May 22, 2006, 03:20 am Last Edit: May 22, 2006, 03:22 am by prisonerjohn Reason: 1
Processing:
Code: [Select]
import processing.serial.*;
*  ezPong_processing
*  copyleft 2006 | Elie Zananiri
*  prisonerjohn@gmail.com
*  based on the Arduino meets Processing tutorials
// serial connection variables
Serial port;
String portName = "/dev/cu.usbserial-3B1";
int baudRate = 19200;
int value = 0;
String buffer="";
int potValue = 0;
// visuals variables
Ball ball;
int ballSize = 10;
Paddle paddle;
int paddleWidth = 80;
int paddleTop = 25;
int paddlePos;
 size(600, 400);
 framerate(30);
 smooth();
 // establish serial port connection
 port = new Serial(this, portName, baudRate);
 // create ball
 ball = new Ball(random(ballSize, width-ballSize), random(ballSize, height-ballSize), ballSize, color(200, 0, 0));
 // create paddle
 paddle = new Paddle(random(paddleWidth, width-paddleWidth), height-paddleTop, paddleWidth, ballSize, color(200, 200, 200));
void serialEvent(int serial){
 if (serial == 10) {
   // if serial is line break store and clear the buffer
   potValue = 1023-int(buffer);
   buffer = "";
 } else if (serial == 60) {
   // if serial event is beep signal clear the buffer
   buffer = "";
   // add an event to the buffer
   buffer += char(serial);
 // convert potValue to the correct range for the paddle position
 paddlePos = (potValue*(width-ballSize-paddleWidth))/1023+ballSize/2;
 // move the paddle
 paddle.move(paddlePos);
void draw() {
 // listen to serial port and trigger serial event
 while (port.available() > 0) {
   value = port.read();
   serialEvent(value);
 // draw graphics
 // erase bg using a semi-transparent square to have a motion blur effect
 drawBG();
 // move and draw the ball
 ball.step();
 // draw the paddle
 paddle.draw();
void drawBG() {
 // draw a semi-transparent rect over the entire canvas to create a motion blur effect
 noStroke();
 fill(200, 200, 100, 150);
 rect(0, 0, width, height);
* class Ball
class Ball {
 // position variables
 float x;
 float y;
 // speed variables
 float dX;
 float dY;
 int frame;
 // graphics variables
 int size;
 color col;
 // constructor
 public Ball(float startX, float startY, int theSize, color theColor) {
   x = startX;
   y = startY;
   size = theSize;
   col = theColor;
   // randomly set a starting speed
   dX = ceil(random(0, 5));
   dY = ceil(random(0, 5));
   frame = 0;
 public void move() {
   x += dX;
   y += dY;
 public void accelerate() {
   dX *= 1.01;
   dY *= 1.01;
 public void draw() {
   stroke(0);
   fill(col);
   ellipse(x, y, size, size);
 public void checkCollisions() {
   // check for right wall collision
   if ((x+size/2) > width) {
     x = width-size-1;
     dX *= -1;
   // check for left wall collision
   } else if ((x-size/2) < 0) {
     x = size+1;
     dX *= -1;
   // check for paddle collision
   if ((y+(size/2) > paddle.y) && (x > paddle.x) && (x < (paddle.x+paddle.w))) {
     y = paddle.y-size-1;
     dY *= -1;
     // send signal to serial
     //port.write(60);
   // check for bottom wall collision
   } else if (y+(size/2) > height) {
     y = height-size-1;
     dY *= -1;
   // check for top wall collision
   } else if (y-(size/2) < 0) {
     y = size+1;
     dY *= -1;
 public void step() {
   move();
   // accelerate ball speed every 30 frames i.e. every second
   if (++frame%30 == 0) {
     accelerate();
   checkCollisions();
   draw();
* class Paddle
class Paddle {
 float x;
 float y;
 int w;
 int h;
 color col;
 // constructor
 public Paddle(float startX, float startY, int theWidth, int theHeight, color theColor) {
   x = startX;
   y = startY;
   w = theWidth;
   h = theHeight;
   col = theColor;
 public void move(float newX) {
   // assign the received x position
   x = newX;
   // set the fill color
   noStroke();
   fill(col);
   // draw the left rounded edge
   ellipse(x, y, h, h);
   // draw the center
   rect(x, y-h/2, w, h);
   // draw the right rounded edge
   ellipse(x+w, y, h, h);
   // set the stroke color
   stroke(0);
   // add the outline around the paddle shape
   line(x, y-h/2, x+w, y-h/2);
   line(x, y+h/2, x+w, y+h/2);
   arc(x, y, h, h, PI/2, -PI/2);
   arc(x+w, y, h, h, -PI/2, PI/2);
prisonerjohn
#2
May 22, 2006, 03:21 am Last Edit: May 22, 2006, 03:24 am by prisonerjohn Reason: 1
Arduino:
Code: [Select]
*  ezPong_arduino
*  based on the following sketches
*   pwm_sound/play_melody
*   serial_comm/analog_read_send
// program variables
int potIn = 2;
int value = 0;
int speakerOut = 5;
int tone = 1915;
int inData = 0;
 // set the pin modes
 pinMode(potIn, INPUT);
 pinMode(speakerOut, OUTPUT);
 // begin sending over serial port
 Serial.begin(19200);
 // read the value using analog input
 value = analogRead(potIn);
 // send value over the serial port...
 printInteger(value);
 // ..and a separator signal
 printByte(10);
 delay(10);
 if (Serial.available() > 0) {
   // read the incoming date
   inData = Serial.read();
   // check if the incoming data is the 'play sound' code
   if (inData == 60) {
     Serial.print(inData, DEC);
      // play a sound through the speaker
     digitalWrite(speakerOut, HIGH);
     delayMicroseconds(tone);
     digitalWrite(speakerOut, LOW);
     // pause
     digitalWrite(speakerOut, 0);
     delayMicroseconds(500);
prisonerjohn
mellis
Your Arduino code looks fine, but you've commented out the call to port.write() in the Processing code.  Is that the problem?  Otherwise, have you tried the speaker code on its own, independent of the serial code?  Does it work?
prisonerjohn
No, that's not the problem, it's just another case of copying/pasting too quickly.
Do Arduino and Processing automatically know what is incoming and what is outgoing data?  Is it possible the signal the Processing code is sending is being read by Processing too or does it just read whatever is being "Serial.written" from other sources?
mellis
Yes, they know what's incoming and what's outgoing.  The serial communication uses two data lines, one in each direction, so there shouldn't be any confusion.
Are you sure your collision detection routine is working properly?  Have you tried printing to the Processing console along with sending serial data?
prisonerjohn
i know the collisions work because the ball bounces back :)
but i will try again with the console when i get home later and see what i get
prisonerjohn
Sorry for replying so late, I totally forgot about this.
I just tested my program again and it works.  I don't know what was wrong, but I'm suspecting it's something like reading from the wrong serial port.
Anyways, thanks for the help.
I'm having another problem with this code that you can check out here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1149391368
