I didn't want to add this on the other thread.
I can get the seconds to go the correct way but instead of having the usual moving 4 pixels it creates a long line of pixels or I get 2 sets of seconds the original 4 pixels going the normal way + the previously mentioned way.
And that is without adjusting any other part of the code but there is also this part of the code to take into consideration which from my experiments last night did affect the way the correction worked.
For some reason when I just add the modification in the part previously advised I get the 2 sets of second hands, and if I play around with the below code I can get 1 set of the second hands going in the correct direction but create a long line of 'pixels' instead of normal one even if I add the (59 -second_led) to each part of the below code or just '//' the lines out
// Show LEDs ------------------ Main loop here -----------------
// Keep this at the top so it doesn't mess up any other settings when LEDs are
// turned on.
strip.setPixelColor(second_led-1,SE_Colour/2);
strip.setPixelColor(second_led-2,SE_Colour/4);
strip.setPixelColor(second_led-3,SE_Colour/8);
strip.setPixelColor(second_led-4,SE_Colour/16);
strip.setPixelColor(second_led-5,0);
// Now start setting LEDs below here.
if (second_led == 0)
strip.setPixelColor(LED_Loop-1, SE_Colour/2);
strip.setPixelColor(LED_Loop-2,SE_Colour/4);
strip.setPixelColor(LED_Loop-3,SE_Colour/8);
strip.setPixelColor(LED_Loop-4,SE_Colour/16);
strip.setPixelColor(LED_Loop-5,0);
new_minute = 1;
if (second_led == 1)
strip.setPixelColor(second_led-1, SE_Colour/2);
strip.setPixelColor(LED_Loop-1, SE_Colour/4);
strip.setPixelColor(LED_Loop-2,SE_Colour/8);
strip.setPixelColor(LED_Loop-3,SE_Colour/16);
strip.setPixelColor(LED_Loop-4,0);
if (second_led == 2)
strip.setPixelColor(second_led-2, SE_Colour/4);
strip.setPixelColor(LED_Loop-1, SE_Colour/8);
strip.setPixelColor(LED_Loop-2,SE_Colour/16);
strip.setPixelColor(LED_Loop-3,0);
if (second_led == 3)
strip.setPixelColor(second_led-3, SE_Colour/8);
strip.setPixelColor(LED_Loop-1,SE_Colour/16);
strip.setPixelColor(LED_Loop-2,0);
if (second_led == 4)
strip.setPixelColor(LED_Loop-1,0);
