Topic: Wall of Shame  (Read 62848 times) previous topic - next topic
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
MorganS
That one's not too bad. Nicely laid out blocks, minimum line-crossings. I hope it comes with the usual disclaimers: "I couldn't find the right battery because I have a 9V battery and I don't have those motors yet and I have a Due not a Mega, but otherwise, that's exactly what I have, except I mixed up the wire colours. Does it matter that I didn't tell you this to begin with?"
"The problem is in the code you didn't post."
larryd
#32
Mar 11, 2016, 09:45 pm Last Edit: Mar 11, 2016, 11:55 pm by LarryD
Hissss
No technical PMs.
TomGeorge
Look at all the current losses in those looonngggg wires......
Tom..... :)
PS. If I need an emetic I know were to come.
Everything runs on smoke, let the smoke out, it stops running....
dave-in-nj
http://forum.arduino.cc/index.php?topic=385983.0
Quote
Quick edit/note: Fritzing diagram included of my previous set up used a Mega2560 board. The shield is obviously mounted on an Uno, but the fundamentals of the set up are unchanged, i just have incorporated the buttons and LCD in a shield on top of an Uno instead.
in other words, this fritzing is not what I am actually doing, what I am doing is different.....
larryd
No technical PMs.
ChrisTenone
This fritzing has some great features! I especially like the wire that seems to connect the power strip to the ground strip, the way both lines from the motor are attached to both input wires, but the best is the wire that goes through the hole on the heatsink on the transistor, and terminates ... on an empty strip?
What, I need to say something else too?
ChrisTenone
This is a wiring diagram of my circuit. Can anyone find the problem? :P
dmjlambert
ChrisTenone
That one is pretty
Thanks dmj. I try to make everything all my projects look good. And actually, this device (an "atomic" clock) works prefecto. But you know, it's never done.
Boardburner2
Have you run out of red crayon ?
ChrisTenone
That's the only thing they'll let me use.
larryd
#42
Mar 14, 2016, 06:53 pm Last Edit: Mar 14, 2016, 06:54 pm by LarryD
This looks strangely similar to Van Gogh's early work.
No technical PMs.
MAS3
I'm sorry, but as a fellow Dutchman i have to set this right.
You might have seen that painting at the van Gogh museum recently, but it isn't a van Gogh.
The van Gogh museum had an exposition called Munch : Van Gogh between september 25th. 2015 and januari 17th. 2016
This piece of art (really) is "Scream" by Edvard Munch (Norwegian: "Skrik").
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
larryd
Oh oh, I am on the wall of shame.
Maybe he painted the the inset image.
No technical PMs.
