Topic: Using the DS1803 digital pot. (Read 5687 times) previous topic - next topic
xSmurf
Hello, I'm trying to interface a DS1803 I2C digital pot without much luck :/
It looks like I'm just writing/reading back the buffer when I communicate with it.
I don't understand why, the address is properly set. And the I2C bus works, I have another device (PCF8574) on it.
If you guys have any idea....
These are the read/write function I'm using. As usual the read address is write+1.
As far as I can see from the datasheet the registers are none looping.
When I write a value and read back, the first is the register address instead of the first byte of data.
Code: [Select]
Void DS1803::setValue(uint8_t value)
     Wire.beginTransmission(DPOT_ADDRESS_W);
     Wire.send(DPOT_WIPERS); // Send the wiper address
     Wire.send(value);
     Wire.endTransmission();
uint8_t DS1803::getValue()
     Wire.requestFrom(DPOT_ADDRESS_R, 2);
     while (Wire.available()) {
           Serial.println((uint8_t)Wire.receive(), DEC);
     return 0;
xSmurf
Got it! Ok so apparently the datasheet gave the address as a 7bit address and I was reading it as an 8bit address. I should have been using 0x28 instead of 0x50... but the fun part is how I figured it out. As someone on IRC suggested I tapped into the twi library and wrote an I2C scanner. Here's the code:
Code: [Select]
void scanTWI(void)
     Wire.begin();
     int ii;
     uint8_t *txBuffer;
     for (ii=1;ii<128;ii++)
           twi_writeTo(ii, txBuffer, 0, 1);
           if (twi_isFound())
                 Serial.println(ii, HEX);
I also had to apply the following modification to the twi.c file:
Code: [Select]
312a313,324
> int foundDevice = 0;
> int twi_isFound(void)
>       if (foundDevice)
>               foundDevice = 0;
>               return 1;
>       return 0;
325a338,340
>               foundDevice = 1;
It's probably terrible code, but as a patch, it works. The question is why isn't something like this in the library? It would be very useful! IMHO at least.
Hope this helps others
xSmurf
#2
Oct 13, 2007, 03:12 am Last Edit: Oct 13, 2007, 03:20 am by xSmurf Reason: 1
You can also do the following:
Add this to the public functions in Wire.h
Code: [Select]
bool checkAddress(uint8_t);
And this in Wire.cpp
Code: [Select]
bool TwoWire::checkAddress(uint8_t twiAddress)
     uint8_t *txBuffer;
     twi_writeTo(twiAddress, txBuffer, 0, 1);
     twi_isFound();
You can now easily check an address by doing Wire.checkAddress(address). w00t  :D
xSmurf
I also added this to the Wire.h so I can detect the mod:
Code: [Select]
#define WIRE_LIB_SCAN_MOD
