Topic: Serial Communication Arduino Uno (Read 402 times) previous topic - next topic
a2pacheco
Hello,
I recently ran into a strange situation with my arduino code and serial monitor. I have the code telling a linear actuator to move back and forth (back and forth once being one cycle) for 20,000 cycles. However, the sketch window & serial monitor closed suddenly, but the linear actuator was still running. Is the linear actuator still running to 20,000 cycles with the code I put? Does it know to stop at 20,000 cycles even without the serial monitor?
Thanks.
DrAzzy
Unless that reset the board (opening a serial connection resets an Arduino unless you clobber the autoreset), it would continue doing what it was doing. The Arduino can't tell if serial is connected, other than via the autoreset when serial connection is opened.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
a2pacheco
