Topic: Arduino as I2C Slave ? (Read 49903 times) previous topic - next topic
JAy1st
Has anyone ever made an Arduino as a Slave I2C ?
I'm planning to use 2 minis as slaves connected to a master Arduino(main cpu + lcd & ethernet).
Is there anything specific I should be aware of ? like I2C address settings or what ever ?
Tnx....
kg4wsv
It's fairly straightforward.  Check the wiring documentation under "Wiring (TWI)" for the master and slave sender and receiver examples.
-j
JAy1st
mmmm, tnx for the link.
Does it allow sending/receiving in the same sketch as well and how to I set up the address ?
Ah ok, adress is the Wire.begin(2) thingy in brackets is it ?
So that means I can use any adress as long there is no conflict.
kg4wsv
Here's a rather idiotic proof of concept I threw together, mostly by copying and pasting code from the wiring.org.co documentation pages.  It's a producer on the slave and a consumer on the master.  The only thing the master sends is the number of bytes requested, which it then prints to the serial port.
A real application would probably need a bit of protocol and probably more bidirectional data flow, but it really depends on what you're doing.
Hope this helps a bit.
-j
i2c_master.c:
Code: [Select]
// i2c/wiring proof of concept code - tie two Arduinos together via
// i2c and do some simple data xfer.
// master side code
// Jason Winningham (kg4wsv)
// 14 jan 2008
#include <Wire.h>
 Wire.begin();        // join i2c bus (address optional for master)
 Serial.begin(9600);  // start serial for output
 Serial.print("master sleeping...");
 delay(2000);
 Serial.println("go");
 Wire.requestFrom(2, 1);    // request data from slave device #2
 while(Wire.available())
   char c = Wire.receive(); // receive a byte as character
   Serial.print(c);         // print the character
 delay(100);
i2c_slave.c:
Code: [Select]
// slave side code
// 14 jan 2008
#include <Wire.h>
 Wire.begin(2);                // join i2c bus with address #2
 Wire.onRequest(requestEvent); // register event
 delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void requestEvent()
 static char c = '0';
 Wire.send(c++);
 if (c > 'z')
   c = '0';
JAy1st
Ah funny my name is Jason too  ;D
Ok I got it.
The plan is to have an arduino running with an ethernet shield (have it already and plyed with) but it's taking lots of memory...
So I'll hook-up a 2nd arduino as a I/O master.
But, an arduino slave can control an I2C RTC or anyotherthing over the same bus ?
I would like to keep the serial for the ethernet one, easing the troubleshooting and debugging....
John_Ryan
Quote
Ok I got it.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1205243372
We've created a PCB with that application in mind. 2 IC's, 2 free serial bus's, with an inline i2c header.
JAy1st
Yes, I did read it and it's good !
(willing to send a bord ?  :D )
So I guess I'll make the "ethernet arduino" a slave and the other one a master to gain access to other I2C bus and take control of RTC and GPIO expanders.......
kg4wsv
Quote
I think that's referred to as a "multiple master" situation, and the answer is, I don't know how it all works.  I'm pretty sure the ATmega can do it, but I don't know how to do it, or if the Wiring library is compatible with multi-master operation.
You can always let the master talk to the clock, then tell the slave what time it is.
-j
JAy1st
As the master/slave is made by coding it should not be to difficult to implement.
I'm gonna order a min a give it a try .
Tnx for your precious help !
