Topic: Blink Multiple LEDs on Arduino Board (Read 1 time) previous topic - next topic
lnichl
Very new beginner to Arduino here.
I am trying to make 3 LEDs blink in sequence, but all the tutorials I have found online are using wires that go to a separate board (a bread board?) and the LEDs have been inserted to that instead.
I want to have all 3 LEDs using the pins on the actual Arduino. I have worked out how to do one (Using Ground and pin 13) I just don't know how to make more output pins for the other ones.
Any help would be greatly appreciated! Thank you.
PaulRB
#1
Mar 07, 2016, 03:00 pm Last Edit: Mar 07, 2016, 03:07 pm by PaulRB
There is a reason why you always see breadboards used. If you stick an led into the Uno's sockets and ground, you will damage the Arduino and the led because too much current will flow. You must use series resistors, probably one for each led. Anything between 100R and 500R will be ok.
Paul
lnichl
#2
Mar 07, 2016, 03:02 pm Last Edit: Mar 07, 2016, 03:07 pm by lnichl
Thank you, having done some further research after posting this I have learnt that you are meant to use resistors!
I am actually attempting to recreate work I did in a class, and the instructor hadn't told us this.
I know this is bad practice (!) but how would I do it anyway, as I don't have any resistors?
PaulRB
Don't. Get some resistors. And some wire and a breadboard.
lnichl
Thank you, I do appreciate this.
But I have a class assignment, and I have to show the LEDs in the arduino (as my instructor had shown me in class) This might not be the best thing to do, but it's a one off and I don't have access to a breadboard and resistors!
I'd be very grateful for any help!
ieee488
Your instructor is an idiot if he expects you to be able to do this project without access to a breadboard and resistors.
PaulRB
In that case, plug them in anywhere you want. Just don't plug in the power, usb or otherwise.
Is your next lesson "how to run with scissors"?
lnichl
He really isn't the best, its got to be said! I've taken your advice, and I've managed to borrow a breadboard from someone. I'm hoping I will be able to follow some of the existing tutorials now.
Thank you for your time, Paul.
marco_c
I suggest that you use resistors and explain to your instructor that you did some research on what to do and this is best practice. If you can explain why, that would be even better. He may also learn something.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
larryd
Quote
Or get his nose out of joint.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
shawnlg
I have used LEDs without resistors on the Arduino by using PWM.  If you have the duty cycle short enough, the light isn't that bright, and I believe most LEDs can handle the short burst of current.  Plus, the Arduino pins don't put out that much current.
I think it's harder than people think to damage the pins.  I've accidentally shorted out a pin and had it output 5 volts.  It was fine :)
You can use pins 3,5,6,9,10, or 11
Use analogWrite(3,5) to turn on the LED in pin 3
Use analogWrite(3,0) to turn it off.
You can change the second number to make the LED brighter or dimmer.
BTW, you can get clone Arduino nanos for $2 or so, so it's not the end of the world if you try something out like hooking up an LED without a resistor.
You learn by doing - even doing dumb things.
Shawn Gordhamer
ieee488
What you do with your hobby is one thing.
This assignment is in a classroom environment which means they should do what is the proper way if you want to eventually call yourself a technician, an engineer, an electrician, or any other kind of professional.
