Topic: Annoying problem (Read 450 times) previous topic - next topic
iliyancho57
After updating the arduino IDE some problems came too. I can't update every schetch - there is a warning message at some uploads and the chip doesent take the code.This text comes:
"Warning: platform.txt from core 'Arduino SAMD (32-bits ARM Cortex-M0+) Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
I am sure ,that other people got the problem too so i will be happy if someone tells me what to do, what to update so there is no problem. Thank you very much.
codlink
There is quite a few major bugs from 1.6.6 and later versions.  And Arduino won't pull them from the downloads.  Go back to 1.6.5.
I will tell that those warnings will not interfere with normal operations and uploading, Arduino changed the way libraries are categorized and they want the library authors to change all the libraries.  Which won't happen.
//LiNK
DrAzzy
That's a warning, not an error. It does not interfere with compilation and may be safely disregarded.
It's the core that it's complaining about. Most cores right now do *NOT* fix that, because "fixing" it breaks compatibility with 1.6.5r5 and earlier, and most people are still using 1.6.5, because 1.6.6 and 1.6.7 are still buggy basket cases that should not have been released in their current state.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
iliyancho57
Yeah but i can't upload some scetsches because of this
codlink
Quote
Go back to 1.6.5.
//LiNK
