Hello, how can I put a Fahrenheit formula into this DHT library? I haven't really tried updating libraries. Also, after that is put into that library, how could these sketches be updated to include the dew point reading? I'd really appreciate any help. I have attached the library file. Here is the dew point formula that I would like to add:
(243.04*(log(h/100)+((17.625t)/(243.04+t)))/(17.625-log(h/100)-((17.625t)/(243.04+t)))*1.8+32)
Here are the 2 sketches I'd like to update:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 7 // what digital pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 //DHT 22 (AM2302)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors. This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
Serial.println("DHTxx test!");
dht.begin();
// Wait a few seconds between measurements.
delay(60000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(f);
Serial.print(" \t");
Serial.print(h);
Serial.print(hif);
Serial.println(243.04*(log(h/100)+((17.625*t)/(243.04+t)))/(17.625-log(h/100)-((17.625*t)/(243.04+t)))*1.8+32);
And sketch 2:
#include <LowPower.h>
#include <BH1750.h>
#include <SFE_BMP180.h>
#include <DHT.h>
#include <Wire.h>
#include "Sodaq_DS3231.h"
#include <SD.h>
#include <SPI.h>
#define DHTPIN 2
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define ALTITUDE 216.0 // Altitude in Sparta, Greece
char TEMPERATURE = 'C' ; //Change it to F to log degrees Fahrenheit
int INTERVAL = 1; //interval of measurements in minutes
DateTime dt(2015, 12, 14, 9, 28, 40, 1); //Date and time
int CS_PIN = 10;
int ledPin = 7;
int POWERPIN = 3;
File file;
DHT dht(DHTPIN,DHTTYPE);
SFE_BMP180 pressureSensor;
BH1750 lightMeter;
int id = 0;
void setup ()
pinMode(POWERPIN, OUTPUT);
digitalWrite(POWERPIN,HIGH);
pinMode(ledPin, OUTPUT);
initializeSD();
//rtc.setDateTime(dt); //Adjust date-time as defined 'dt' above
void loop ()
String temperature;
String humidity;
String light;
String pressure;
String entryId;
String dateEntry;
id++;
digitalWrite(ledPin,HIGH);
delay(2000);
initSensors();
delay(10000);
entryId = String(id);
humidity = String(dht.readHumidity());
if(TEMPERATURE =='F')
temperature = String(dht.readTemperature(true));
}else
temperature = String(dht.readTemperature());
pressure = readPressure();
light = readLight();
dateEntry = DateLogEntry();
String entry = entryId+","+dateEntry+","+temperature+","+humidity+","+pressure+","+light;
writeEntryToFile(entry);
delay(2000);
sleepForMinutes(INTERVAL);
void initSensors()
Wire.begin();
rtc.begin();
dht.begin();
pressureSensor.begin();
lightMeter.begin();
void sleepForMinutes(int interval)
int i=0;
int seconds = interval*60;
int iterations = seconds/8;
for (byte i = 0; i <= A5; i++)
pinMode (i, OUTPUT); // changed as per below
digitalWrite (i, LOW); // ditto
digitalWrite(POWERPIN,LOW);
for(i=0;i<iterations;i++)
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
float readPressureFromSensor()
char status;
double T,P,p0,a;
status = pressureSensor.startTemperature();
if (status != 0)
delay(status);
status = pressureSensor.getTemperature(T);
if (status != 0)
status = pressureSensor.startPressure(3);
if (status != 0)
delay(status);
status = pressureSensor.getPressure(P,T);
if (status != 0)
p0 = pressureSensor.sealevel(P,ALTITUDE);
return p0;
String DateLogEntry()
String dateEntry;
String year;
String month;
String day;
String hour;
String minute;
DateTime now = rtc.now();
year = String(now.year());
month = String(now.month());
day = String(now.date());
if(now.hour()<10)
hour = "0"+String(now.hour());
}else
hour = String(now.hour());
if(now.minute()<10)
minute = "0"+String(now.minute());
}else
minute = String(now.minute());
dateEntry = month+"/"+day+"/"+year+" "+hour+":"+minute;
return dateEntry;
String readLight()
uint16_t lux = lightMeter.readLightLevel();
return String(lux);
String readPressure()
String pressure;
pressure = String(readPressureFromSensor());
return pressure;
void initializeSD()
pinMode(10, OUTPUT); // change this to 53 on a mega // don't follow this!!
digitalWrite(10, HIGH); // Add this line
if (SD.begin(CS_PIN))
digitalWrite(ledPin,LOW);
} else
return;
int openFileToWrite(char filename[])
file = SD.open(filename, FILE_WRITE);
if (file)
delay(200);
delay(200);
delay(200);
return 1;
} else
return 0;
int writeToFile(String text)
if (file)
file.println(text);
return 1;
} else
return 0;
void closeFile()
if (file)
file.close();
void writeEntryToFile(String entry)
openFileToWrite("log.txt");
writeToFile(entry);
closeFile();
DHT.txt (8.35 KB)
