Topic: usb connector - use the "5th" wire (Read 1 time) previous topic - next topic
Bart007
Mar 09, 2016, 08:24 pm Last Edit: Mar 09, 2016, 08:55 pm by Bart007
Hi Guys,
Im making an handheld device with buttons and lights. This is connected with an usb to the "main device"
things i need to send/recieve
5 v
ground
data (to LEDs from main)
data (from buttons to main)
now i like to hook up a LED when you plug the usb in the LED wil get on.
is it possible to use the "5th wire" for this?
Zapro
Mini/Micro-USB-leads do have 5 wires, although the cable does not carry 5 wires.
The 5th pin is usually used as ID, wired to ground directly or trough a resistor.
// Per.
DrAzzy
The 5th pin is "insert detect", and that's exactly what the pin is for. I think it's connected to ground when plugged in? You can check what it's connected to with your multimeter.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Paul__B
But it has been frequently used for headsets and such.
dlloyd
Connecting pin4 to pin5 creates an "OTG" cable for USB Host applications. Pinout
