Topic: binary counter (Read 1 time) previous topic - next topic
jonscone
I'm trying to write code to create a 5-bit binary counter. The counter should count up once per second and display the current count value (from 00000 to 11111) using the 5 LEDs I have. I've tried using the function bitRead(x,n) to work out what the value to each bit is to assign it to the LED's, but I honestly have no idea what I'm doing. Someone please help me!!! :)
larryd
Welcome.
Show us the sketch that you have at this point.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
jonscone
This is what I have so far:
int led1 = 9;
int led2 = 8;
int led3 = 7;
int led4 = 6;
int led5 = 5;
  // initialize the digital pin as an output.
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  digitalWrite(led5, bitRead(count,4));
  digitalWrite(led4, bitRead(count,3));
  digitalWrite(led3, bitRead(count,2));
  digitalWrite(led2, bitRead(count,1));
  digitalWrite(led1, bitRead(count,0));
  count=count+1;
larryd
#3
Mar 15, 2016, 01:26 am Last Edit: Mar 15, 2016, 01:32 am by LarryD
Almost:
Code: [Select]
const byte led1 = 9;
const byte led2 = 8;
const byte led3 = 7;
const byte led4 = 6;
const byte led5 = 5;
byte count = 0;
  count=count+1;
If your LEDs are reversed
Code: [Select]
  digitalWrite(led5, !bitRead(count,4));
  digitalWrite(led4, !bitRead(count,3));
  digitalWrite(led3, !bitRead(count,2));
  digitalWrite(led2, !bitRead(count,1));
  digitalWrite(led1, !bitRead(count,0));
No technical PMs.
larryd
How are you wiring your LEDs?
No technical PMs.
guix
Hello and welcome,
You may find this post interesting :)
AndrewGhattas
I haven't found anyone who did it like this. It doesn't use modulo or binary masks, or any fancy library functions.
Basically, the idea is that any given bit will go from zero to one if all the bits that are less-significant than it were ones. So if you find "n" continuous ones beginning from the least significant bit, flip the "n+1" least significant bits.
Here's one way I did it:
Code: [Select]
This uses the 10 LED display
It's a binary counter written by Andrew Ghattas
/* sorry, I didn't bother checking if this boolean array was necessary or if I could use a pin output state in an "if" statement
bool pinstates[] = {false,false,false,false,false,false,false,false,false,false};
// you can arrange these the opposite way, depending on which way your circuit is "looking" at you
int ledPins[] = {12,11,10,9,8,7,6,5,4,3};
// the setup function runs once when you press reset or power the board
  // initialize digital pins as outputs
  for (int i = 0; i < 10;i++) {
  pinMode(ledPins[i], OUTPUT); }
// the loop function runs over and over again forever
if (pinstates[8] && pinstates[7] && pinstates[6] && pinstates[5] && pinstates[4] && pinstates[3] && pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(9);
else if (pinstates[7] && pinstates[6] && pinstates[5] && pinstates[4] && pinstates[3] && pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(8);
else if (pinstates[6] && pinstates[5] && pinstates[4] && pinstates[3] && pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(7);
else if (pinstates[5] && pinstates[4] && pinstates[3] && pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(6);
else if (pinstates[4] && pinstates[3] && pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(5);
else if (pinstates[3] && pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(4);
else if (pinstates[2] && pinstates[1] && pinstates[0])
  fliploop(3);
else if (pinstates[1] && pinstates[0])
  fliploop(2);
else if (pinstates[0])
  fliploop(1);
  fliploop(0);
//starting from least significant bits
void fliploop(int numberofbitstoflip) {
  for (int i = 0; i <= numberofbitstoflip; i++)
    flipbit(i);
void flipbit(int i) {
  pinstates[i] = ! pinstates[i];
  if (pinstates[i])
    digitalWrite(ledPins[i], HIGH);
    digitalWrite(ledPins[i],LOW);
A more elegant way of writing it looks like this:
Code: [Select]
This uses the 10 LED display to display a binary counter.
Written by Andrew Ghattas.
int ledPins[10] = {12,11,10,9,8,7,6,5,4,3};
const int numberofleds = 10;
/* pins start at zero
sorry, I didn't bother checking if this array was necessary or if I could use pin output states in an "if" statement
int pinstates[10] = {0,0,0,0,0,0,0,0,0,0};
  // initialize digital pins as outputs.
  for (int i = 0; i < numberofleds;i++)
  delay(100);
  fliploop(leastsignificantones());
int leastsignificantones() {
  int i = 0;
  while (pinstates[i] == 1 && i <= numberofleds - 2) {
    i = i + 1;
  return i ;
    flipbit(i);
  if (pinstates[i] == 0) {
    pinstates[i] = 1;
  else {
    pinstates[i] = 0;
I hope you find this code insightful...  or at least entertaining!
Paul__B
Well, someone might, but "jonscone" has not been to this forum for over three years, so I doubt he will!  :smiley-eek:
