I would be glad if you could help me on this code, the problem is, 3-channel x 170 = 510 DMX channels in this software. 2x512 how I can do this by modifying the software. I want to use to connect more LEDs. So how do I edit 2 as Artnet.
In short, if you want to edit 2 universe as ArtNet
Meanwhile sorry for my bad english.
Thank you.
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
// Neopixel settings
const int numLeds = 240; // change for your setup
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 2;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {192, 168, 2, 2};
byte mac[] = {0x04, 0xE9, 0xE5, 0x00, 0x69, 0xEC};
//Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
sendFrame = 1;
// set brightness of the whole strip
if (universe == 15)
leds.setBrightness(data[0]);
leds.show();
// Store which universe has got in
if ((universe - startUniverse) < maxUniverses)
universesReceived[universe - startUniverse] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived == 0)
//Serial.println("Broke");
sendFrame = 0;
// read universe and put into the right part of the display buffer
for (int i = 0; i < length / 3; i++)
int led = i + (universe - startUniverse) * (previousDataLength / 3);
if (led < numLeds)
leds.setPixelColor(led, data[i * 3], data[i * 3 + 1], data[i * 3 + 2]);
previousDataLength = length;
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < numLeds ; i++)
leds.setPixelColor(i, 127, 0, 0);
leds.show();
leds.setPixelColor(i, 0, 127, 0);
leds.show();
leds.setPixelColor(i, 0, 0, 127);
leds.show();
leds.setPixelColor(i, 0, 0, 0);
leds.show();
