Topic: split string by delimiters (Read 120495 times) previous topic - next topic
drmpf
There is now a SafeString library available from the Arduino Library manager which includes a number of tokenizer methods and a simple effective example of parsing user input for keywords without blocking the rest of the sketch  from running
SafeStrings do not cause heap fragementation and never cause the sketch to reboot and have detail debugging available.
Code: [Select]
  input.read(Serial)
  // read from Serial, returns true if at least one character was added to SafeString input
  if (input.nextToken(token, delimiters)) { // process at most one token per loop does not return tokens longer than input.capacity()
    if (token == startCmdStr) {
      running = true;  Serial.print(F("start at ")); Serial.println(loopCounter);
    } else if (token == stopCmdStr) {
      running = false; Serial.print(F("stop at ")); Serial.println(loopCounter);
    } else if (token == resetCmdStr) {
      loopCounter = 0; Serial.print(F("reset Counter:")); Serial.println(loopCounter);
    }// else  // not a valid cmd ignore
  // rest of code here is executed while the user typing in commands
  if (running) {
    loopCounter++;
    if ((loopCounter % 100000) == 0) {
      Serial.print(F("Counter:")); Serial.println(loopCounter);
EasyGoing1
As you might have gathered I wasn't entirely serious about programming an Arduino in MUMPS.
I learned a language called FROG ... way back in high school ... I think DOS was on version 2 or 3 back then ... 1986-ish
Mike Sims
