Topic: controlling ESCs with a parallax joystick (Read 639 times) previous topic - next topic
aphocks
If I have this code which controls two servos with a joystick how do I make it so that instead of controlling a servo motor, it controls a Forward/reverse ESC?  I need it to control 4 ESCs.  (motor one and two ccw when joypushed foreward, cw when back, and motor three and four are ccw when joy is pushed right, cw when left.)
pleeeeaaase help me.  This is one of the last steps for my ROV and I've put so much work into it, I just want to see it swim!
#include <Servo.h>
const int servo1 = 3;       // first servo
const int servo2 = 10;       // second servo
const int joyH = 3;        // L/R Parallax Thumbstick
const int joyV = 4;        // U/D Parallax Thumbstick
int servoVal;           // variable to read the value from the analog pin
Servo myservo1;  // create servo object to control a servo
Servo myservo2;  // create servo object to control a servo
  // Servo
  myservo1.attach(servo1);  // attaches the servo
  myservo2.attach(servo2);  // attaches the servo
  // Inizialize Serial
void loop(){
    // Display Joystick values using the serial monitor
    outputJoystick();
    // Read the horizontal joystick value  (value between 0 and 1023)
    servoVal = analogRead(joyH);
    servoVal = map(servoVal, 0, 1023, 0, 180);     // scale it to use it with the servo (result  between 0 and 180)
    myservo2.write(servoVal);                         // sets the servo position according to the scaled value
    servoVal = analogRead(joyV);
    servoVal = map(servoVal, 0, 1023, 70, 180);     // scale it to use it with the servo (result between 70 and 180)
    myservo1.write(servoVal);                           // sets the servo position according to the scaled value
    delay(15);                                       // waits for the servo to get there
* Display joystick values
void outputJoystick(){
    Serial.print(analogRead(joyH));
    Serial.print ("---");
    Serial.print(analogRead(joyV));
    Serial.println ("----------------");
zoomkat
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
aphocks
Got it, here:
Code: [Select]
#include <Servo.h>
  // Servo
void loop(){
    outputJoystick();
