Topic: How to count the number of steps a stepper motor has made and update it on LCD? (Read 9188 times) previous topic - next topic
pooja2788
Hello everyone,
I am building a programmable stepper motor. It contains arduino mega 2560, lcd keypad shield, nema 14 stepper motor, a opto interrupter sensor and a stepper motor driver (polulu DRV8825). I am stuck at one point. I want to update the lcd screen everytime the motor takes 1 step. The number of steps, speed of motor and direction will be user input. Also, I want to set the speed of the stepper motor according to the input entered using the keypad shield. But I don't know how to make this thing work. Any idea what should be the logic? Please help me out with this issue I am having.
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
pooja2788
Hi Larry,
Thank you for the link. The functions for a servo motor are not the same as stepper. Correct?
larryd
The two motors are completely different.
Your stepping motor can be advanced one step at a time. Lots are 1.8 degrees per step.
There are a lot of Arduino/stepping motor hits on the Internet.
Maybe look at YouTube for some stepping motor offerings.
https://m.youtube.com/results?q=stepping%20motor&sm=3
No technical PMs.
larryd
No technical PMs.
Robin2
Also have a look at this Simple Stepper Code and at Stepper Motor Basics
The simple answer to the question in your title is to command the motor to move one step at a time and increment a variable once for every step. Then the code for your LCD can read the value in that variable and display it on the screen.
Writing to an LCD is time consuming so you probably won't want to update the display for every step unless the motor is moving very slowly. It may be sufficient to update the display once or twice per second.
Do not use the delay() function anywhere in your program.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
pooja2788
Hello Robin,
Thank you for helping me out. Well its a project I am doing for my final semester. My professor asked me to display it on the lcd for every step the motor takes. I have no choice, but to do it. What if I display the revolution instead of displaying steps? Will it help solving the problem I am having?
larryd
You say will it help with the problem I am having.
Show us your work so we can help you with that problem.
Updating your LCD faster than 3-4 times a second is useless.
No technical PMs.
pooja2788
digitalWrite(dirPin, direct2);
   for (int x = 0; x < steps2*200; x++)
       digitalWrite(stepPin, HIGH);
       delayMicroseconds(500);
       digitalWrite(stepPin, LOW);
     lcd.setCursor(2, 1);
     lcd.print("Back to Home    ");
     digitalWrite(dirPin, !direct2);
   lcd.clear();
   delay(200);
   lcd.setCursor(0, 0);
   lcd.print("Done");
   delay(4000);
void lcdstatus()
  // Serial.println(status);
  if (status == 1)
    lcd.clear();
    lcd.print("Enter # of steps");
    lcd.setCursor(0, 1);
    lcd.print(steps1);
  if (status == 2)
    lcd.clear();
    lcd.print("Enter Speed");
    lcd.print(speed1);
  if (status == 3)
    lcd.clear();
    lcd.print("Enter direction");
    lcd.print(direct1);
  if (status == 4)
    lcd.clear();
    lcd.print("Ready to go");
    lcd.setCursor(0,1);
    lcd.print("Press Select Key");
This is the logic I have written for using the lcd keypad shield. I was trying to put the steps2 value in a new variable and then increment it but its simply showing me the value on the lcd. Its not updating. I am not having much idea about arduino commands. Is there a way I can use a counter or limit condition to count the steps?
larryd
Please, you must show us your complete sketch. Attach your code using the </> icon on the left side of the posting menu.
You are going to have to remove delay() functions if you want a responsive project.
Are you familiar with using millis() to achieve unblocking delays, see BWD (Blink Without Delay).
Tackle this project one section at a time, when you have things working separately, put things together.
No technical PMs.
pooja2788
Code: [Select]
#include <LiquidCrystal.h>
//#include<Stepper.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int stepsPerRevolution;
const int stepPin = 32;
const int dirPin = 30;
// Here set the stepper motor rotation step to check when does the motor make one revolution//
int dim = stepsPerRevolution;
// Set the step motor number and pin
//Stepper myStepper(stepsPerRevolution, 7, 11, 12, 13);
int ans = 0;
int a = 0; //used for moving the cursor left or right.
int status=1;
int steps1=0;
int speed1=0;
int direct1=0;
int steps2=0;
int speed2=0;
int direct2=0;
int go;
int val;
  lcd.begin(16, 2);
  //lcd.print("Prog Step Motor");
  //Serial.begin(9600);
  //lcd.begin(16, 2);
  //lcd.print("Enter Rotations: ");
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  val = analogRead(0); // used by Lcd
  lcd.setCursor(a, 1);
    if (val < 60)
    //Right PB.
      lcd.clear();
      if (status < 4)
          if (status >= 1)
               status++;
               delay(200);
      delay(200);
  else if (val < 200)
  //up button
    if (status == 1)
          steps1++;
        delay(200);
    if (status == 2)
          speed1++;
    if (status == 3)
      if (direct1 < 1)
        if (direct1 >= 0)
          direct1++;
        delay(200);
  else if (val < 400) {
    //down button
    if (status == 1)
          steps1--;
        delay(200);
    if (status == 2)
          speed1--;
    if (status == 3)
      if (direct1 = 1)
        if (direct1 >= 1)
        direct1--;
        delay(200);
  else if (val < 600) {
    //left button
    lcd.clear();
    if (status > 1)
      status--;
      delay(200);
      //a--;
      delay(200);
  else if (val < 800) {
    //want to use this to save the value and move onto another function.
    //if (val = 1023)
      //int val=ans;
      //Serial.println(val);
     // if (status == 1)
        steps2 = steps1;
        speed2 = speed1;
        direct2 = direct1;
      if (status == 4)
        go = 1;
        lcd.print("Run the Motor");
        Serial.print("go=");
        Serial.println(go);
        runStep();
       delay(200);
       delay(10);
       lcdstatus();
//myStepper.setSpeed(60);
void runStep()
    Serial.print("steps1=");
    Serial.println(steps1);
    Serial.print("speed1=");
    Serial.println(speed1);
    Serial.print("direct1=");
    Serial.println(direct1);
    Serial.print("steps2=");
    Serial.println(steps2);
    Serial.print("speed2=");
    Serial.println(speed2);
    Serial.print("direct2=");
    Serial.println(direct2);
  // clockwise rotation
  lcd.clear();
  delay(200);
  lcd.setCursor(2, 0);
  lcd.print("Motor running");
  lcd.setCursor(4, 1);
   if (direct2==1)
   lcd.print("CLW => 1");
   if (direct2==0)
   lcd.print("CCW => 0 ");
   delay(100);
   lcd.clear();
   delay(200);
   lcd.print("Done");
   delay(4000);
void lcdstatus()
  if (status == 1)
    lcd.clear();
    lcd.print(steps1);
  if (status == 2)
    lcd.clear();
    lcd.print(speed1);
  if (status == 3)
    lcd.clear();
    lcd.print(direct1);
  if (status == 4)
    lcd.clear();
    lcd.setCursor(0,1);
Here is the code I have written so far.
larryd
No technical PMs.
pooja2788
larryd
The 'if' function uses == you have =
= is an assignment operator
== is a comparison operator
- Try a simple LCD sketch example to make sure you have everything connected properly.
- What is your sketch not doing?
No technical PMs.
