Topic: 1-Wire Slave (Read 87457 times) previous topic - next topic
aivs
I don't know why, but with some devices previous code didn't work. But with ROM from real DS18B20 all works fine, so in this code I use ROM from real device and send brightness at request.
Code: [Select]
#include "Arduino.h"
#include "LowLevel.h"
#include "OneWireSlave.h"
// Defines to access to Low and High bytes
#define Lo(x)   ((x) & 0xFF)
#define Hi(x)   (((x)>>8) & 0xFF)
// This is the pin that will be used for one-wire data (depending on your arduino model, you are limited to a few choices, because some pins don't have complete interrupt support)
// On Arduino Uno, you can use pin 2 or pin 3
Pin oneWireData(2);
#define brightnessPin 0
// This is the ROM the arduino will respond to, make sure it doesn't conflict with another device, 0x28 - DS18B20 identificator
const byte owROM[] = {0x28, 0xF2, 0x27, 0xD6, 0x05, 0x00, 0x00, 0x96};
// 0 - Low Byte Temperature
// 1 - High Byte Temperature
// 2-7 - reserved
// 8 - CRC8
byte SCRATCHPAD[] = {0x00, 0x00, 0x4B, 0x46, 0x7F, 0xFF, 0x05, 0x10, 0x00};
int brightness = 0;
// This function will be called each time the OneWire library has an event to notify (reset, error, byte received)
void owReceive(OneWireSlave::ReceiveEvent evt, byte data);
// Setup the OneWire library
OneWire.setReceiveCallback(&owReceive);
OneWire.begin(owROM, oneWireData.getPinNumber());
  Serial.print("brightness=");
  Serial.println(brightness);
  delay(5000);
cli();//disable interrupts
sei();//enable interrupts
void owReceive(OneWireSlave::ReceiveEvent evt, byte data) {
switch (evt) {
    case OneWireSlave::RE_Reset:
    case OneWireSlave::RE_Byte:
      // Start measuring brightness
      if (data == 0x44) {
        brightness = analogRead(brightnessPin);
        // Add brightness to the SCRATCHPAD
        SCRATCHPAD[0] = Lo(brightness*16);
        SCRATCHPAD[1] = Hi(brightness*16);
        // Add CRC8 to the SCRATCHPAD
        SCRATCHPAD[8] = OneWire.crc8(SCRATCHPAD,8);
      // Read Scratchpad [BEh] command
      if (data == 0xBE) {
        // Send SCRATCHPAD 9 byte with brightness and CRC
        for (byte i = 8, j = 1; j<=9; i--, j++) {
          OneWire.write(&SCRATCHPAD[i], j, NULL);
    case OneWireSlave::RE_Error:
  default:
milimilo
@Youen
Thank you for your answer.
Blocktalkers
Hi, I am trying to port the one wire libraries from Arduino to ATTiny85. My sketch, which just returns addresses of all slaves on the line, works on Arduino Uno Master - Uno Slave combination. But when I program the same sketch with .cpp and .h files into the ATtiny85 slave at 8MHz internal clock or 1MHz internal clock, I don't get the addresses as intended on my serial monitor. What might be the problem? I am using only ds.init(rom) and ds.waitForRequest(false) functions in my sketch.
abc2006
i read this thread highly interested, because i want to make my Water-Counter one-Wire-accessable with an Arduino Nano and the DS9490R. I tried both Sources, from Post #102 and #105, but the device does not appear in the List of my OW-Server (Linux Ubuntu).
Then i put a Serial.println("RESET"); in the RESET-Part of the
This produces 8 RESET-Entries in my Serial Console (one for every native DS18B20 that i'm using on my BUS).
So the Uno recognizes the Signal from the Controller.
I also put another Serial.print in the RE_Byte-Part, but after Reading Post #103, i wondered if this could be my Problem.
But the original Program without any changes also does not work.
I could remove my Arduino Uno out of my Productive environment for testing, but i don't really belive it would solve my problem.
Can you help? Any suggestions?
Thanks
Stephan
Blocktalkers
There have been a few brief discussions of a 1-Wire slave library.  I'd like to revisit the idea.
3. Is it possible for an AVR processor to run from "parasitic power"?
Hi, has anybody found a way to parasitically power the ATtiny85 slaves? I got it working for 1-Wire using Markus' library, but parasitic power requires the use of two pins - Tx and Rx.
Any suggestions would be very helpful.
Thanks
palsbo
Hi
I have not been succesful in getting this (the code included in the post - #58) to work.
I am using Arduino IDE 1.6.7 and programming the ATtiny85 (8Mhz) with Arduino Nano.
The code compile but no response from the 1-wire. Code in later in this topic will not compile.
Any suggestions are appreciated.
Erik
palsbo
I am trying to get the source in post #59 to work on an ATtiny85, running 8Mhz.
It compiles and upload (using Arduino 1.6.7), but I cannot  see the device (on OWFS).
ATtiny lib is version 1.0.1 by David A Melis (http://highlowtech.org/?p=1695);
What am I doing wrong?
Coolbert
Hello, I implemented the code posted in #104 and  #105 on two arduino nano, one master and second one slave. The command sent by master (i.e. 0xBE, 0x44) is correctly received by slave. But the communication in the other direction fails, the data received by master do no comply with those sent by the slave.
Another problem occures during device search. The arduino slave can't be found if alone on the bus. But with an original DS18B20 on the bus, all devices were recognized (incl. arduino slave).
I replaced the Nano slave by a mega 2560 without any improvement.
Any idea what's going wrong?
regards,
CB
hjfabius
    I'm trying using the 1-Wire Slave Library and I'm really far to make it working.
I've a master that it's able to read a DS18B20 without any problem.
When I replace it with the Arduino Slave, it does not work (Reset signal is recognized but master does not receive the address).
I replaced the library with this one and it works like a charm, so the wiring is ok.
I suspect the reason why the 1-Wire Slave Library does not work is related timing.
In the implementation i noted:
Code: [Select]
const unsigned long ResetMinDuration = 480;
const unsigned long ResetMaxDuration = 900;
const unsigned long PresenceWaitDuration = 30;
const unsigned long PresenceDuration = 300;
const unsigned long ReadBitSamplingTime = 25;
const unsigned long SendBitDuration = 35;
that are used by
Code: [Select]
void OneWireSlave::setTimerEvent_(short delayMicroSeconds, void(*handler)())
In my case, I'm using and Arduino Pro Mini 3.3V that is running 8MHz.  I suspect that the above settings are related to 16MHz arduino.
Could you confirm that the implementation is frequency dependent?
If it's the case does anyone have the setting for 8MHz?
Thanks
hjfabius
Youen
There is indeed a risk that any change on the arduino hardware results in timing issues. Most of the code should be independent of the microcontroller frequency (it counts microseconds, not ticks), but even then, if instructions are executed slower maybe you'll need to adjust by waiting a little less here and there, if at all possible.
There is also a part that is clearly dependent on frequency: the timer configuration. It is currently configured for 16MHz, and halving that frequency will double all timer durations. The timer is used when an event must happen after a predetermined time, rather than on an input pin state change (i.e. reset detection and bit reading).
The relevant line is probably this one:
tccr1bEnable_ = (1 << WGM12) | (1 << CS11) | (1 << CS10); // turn on CTC mode with 64 prescaler
which is used to configure the timer in function setTimerEvent_
You'll need to check the documentation of your microcontroller to find how to set the prescaler to 32 instead of 64. I should probably replace this code by a portable timer library if I find one...
To debug this kind of "fast" communications (with timings of a few microseconds), you might need a digital oscilloscope (I would probably not have managed to get it to work on my Uno without one), since you can't debug by logging to the serial port (too slow). I've bought mine for about $50 (second hand), it connects to the computer through USB to visualize data.
Youen
For those interested with using my library with an ATTiny, you might find what you want in ntruchsess fork. Don't know the status (probably work in progress), but apparently he is working on it.
