Topic: Arduino and matlab (Read 335 times) previous topic - next topic
aromanillos
Hello, I am trying to read my voltage output of arduino due with Matlab (serial port). However, I need to read the pin at least at 120 Hz. By reading directly i only could read at 10 Hz, so I have increased bps to the maximum. I am able to read 120 per second, but the samples are asynchonous, that is, the time spacing between samples are not the same. I guess it could be because the serial comunication is sending information so reading procedure is disturbed.
Does anybody knows a reliable for of reading arduino pins at that frequency? I am using the progremable port, but there is also a native USB port. May I use tha tport instead? I could I read the information from that port?
This is the arduino code I am using right know. Bps have been changed
int val = 0;
  Serial.begin(57600);
  Serial.println('a');
  char a = 'b';
  while (a != 'a')
    a = Serial.read();
  while (Serial.available() == 0)
  if (Serial.available() > 0)
   val = Serial.read();
   if (val == 'R')
      int sensorValue = analogRead(A0);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
      float voltage = sensorValue *(3.3/ 1023.0);
       Serial.println(voltage);
