Topic: WS2812B LED strip controlled by UNO not lighting (Read 6474 times) previous topic - next topic
MikeSch
For a project my team is making bike turn signals and we wanted to us an addressable LED strip for the indicators. We purchased this strip:
http://www.amazon.com/ALITOVE-WS2812B-Individually-Addressable-Waterproof/dp/B00ZHB9M6A/ref=sr_1_1?s=hi&ie=UTF8&qid=1459456402&sr=8-1&keywords=B00ZHB9M6A
We downloaded the Adafruit libraries, ran testers and examples, watched countless videos but we cannot seem to properly get the LEDs to light. We are using a 5v external power supply with a 1000microFarad capacitor connected directly to the strip. The DIN lead is connected via 330ohm resistor to the UNO board that is powered with the USB input from the computer (is this a problem?).
This youtube video (https://www.youtube.com/watch?v=VAa4duqMrgs) was what we felt came the closest to working, though we could be wrong. The code from the video is:
Code: [Select]
#define WS2812_pin 8 // only digital pin 8 works right now
#define numberOfLEDs 150// total number of RGB LEDs
byte RGB[450];//take your number of LEDs and multiply by 3
// FUNCTIONS HERE
void RGB_update(int LED, byte RED, byte GREEN, byte BLUE);//function to drive LEDs
  pinMode(WS2812_pin, OUTPUT);
}//setup
RGB_update(0,0,0,0);//LED#, RED, GREEN, BLUE
}//loop
//WS2812 Driver Function
void RGB_update(int LED, byte RED, byte GREEN, byte BLUE) {
  // LED is the LED number starting with 0
  // RED, GREEN, BLUE is the brightness 0..255 setpoint for that LED
  byte ExistingPort, WS2812pinHIGH;//local variables here to speed up pinWrites
  if(LED>=0){//map the REG GREEN BLUE Values into the RGB[] array
  RGB[LED * 3] = GREEN;
  RGB[LED * 3 + 1] = RED;
  RGB[LED * 3 + 2] = BLUE;
  noInterrupts();//kill the interrupts while we send the bit stream out...
  ExistingPort = PORTB; // save the status of the entire PORT B - let's us write to the entire port without messing up the other pins on that port
  WS2812pinHIGH = PORTB | 1; //this gives us a byte we can use to set the whole PORTB with the WS2812 pin HIGH
  int bitStream = numberOfLEDs * 3;//total bytes in the LED string
//This for loop runs through all of the bits (8 at a time) to set the WS2812 pin ON/OFF times
  for (int i = 0; i < bitStream; i++) {
    PORTB = WS2812pinHIGH;//bit 7  first, set the pin HIGH - it always goes high regardless of a 0/1
    //here's the tricky part, check if the bit in the byte is high/low then right that status to the pin
    // (RGB[i] & B10000000) will strip away the other bits in RGB[i], so here we'll be left with B10000000 or B00000000
    // then it's easy to check if the bit is high or low by AND'ing that with the bit mask ""&& B10000000)"" this gives 1 or 0
    // if it's a 1, we'll OR that with the Existing port, thus keeping the pin HIGH, if 0 the pin is written LOW
    PORTB = ((RGB[i] & B10000000) && B10000000) | ExistingPort;
    __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t");//these are NOPS - these let us delay clock cycles for more precise timing
    PORTB = ExistingPort;//okay, here we know we have to be LOW regardless of the 0/1 bit state
    __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t");//minimum LOW time for pin regardless of 0/1 bit state
    // then do it again for the next bit and so on... see the last bit though for a slight change
    PORTB = WS2812pinHIGH;//bit 6
    PORTB = ((RGB[i] & B01000000) && B01000000) | ExistingPort;
    PORTB = WS2812pinHIGH;//bit 5
    PORTB = ((RGB[i] & B00100000) && B00100000) | ExistingPort;
    PORTB = WS2812pinHIGH;//bit 4
    PORTB = ((RGB[i] & B00010000) && B00010000) | ExistingPort;
    PORTB = WS2812pinHIGH;//bit 3
    PORTB = ((RGB[i] & B00001000) && B00001000) | ExistingPort;
    PORTB = WS2812pinHIGH;//bit 2
    PORTB = ((RGB[i] & B00000100) && B00000100) | ExistingPort;
    PORTB = WS2812pinHIGH;//bit 1
    PORTB = ((RGB[i] & B00000010) && B00000010) | ExistingPort;
    PORTB = WS2812pinHIGH;//bit 0
    __asm__("nop\n\t");//on this last bit, the check is much faster, so had to add a NOP here
    PORTB = ((RGB[i] & B00000001) && B00000001) | ExistingPort;
    PORTB = ExistingPort;//note there are no NOPs after writing the pin LOW, this is because the FOR Loop uses clock cycles that we can use instead of the NOPS
  }//for loop
  interrupts();//enable the interrupts
// all done!
}//void RGB_update
We purchased two different strips with the same WS2812B IC's and the LEDs do occasionally flash when connected to power so we do not think that the strips are to blame.
Any help in getting the strips lit would be greatly, greatly appreciated!
ieee488
#1
Mar 31, 2016, 11:44 pm Last Edit: Mar 31, 2016, 11:44 pm by ieee488
I am guessing is going to turn off LED #0
I use the FastLED library myself.
Qdeathstar
FastLED library is vastly superior.
Make sure you make the data connections at the right end (it only works one way) and connect power supply ground and Arduino ground.
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
MikeSch
I just tried using the FastLED blink example
Code: [Select]
#include "FastLED.h"
// How many leds in your strip?
#define NUM_LEDS 150
// For led chips like Neopixels, which have a data line, ground, and power, you just
// need to define DATA_PIN.  For led chipsets that are SPI based (four wires - data, clock,
// ground, and power), like the LPD8806 define both DATA_PIN and CLOCK_PIN
#define DATA_PIN 6
#define CLOCK_PIN 13
// Define the array of leds
CRGB leds[NUM_LEDS];
      // Uncomment/edit one of the following lines for your leds arrangement.
      // FastLED.addLeds<TM1803, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<TM1804, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<TM1809, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
      FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
      // FastLED.addLeds<APA104, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<UCS1903B, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<GW6205, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<GW6205_400, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<SM16716, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<LPD8806, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<P9813, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<APA102, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<DOTSTAR, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<SM16716, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<P9813, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<DOTSTAR, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
  // Turn the LED on, then pause
  leds[0] = CRGB::Red;
  FastLED.show();
  // Now turn the LED off, then pause
  leds[0] = CRGB::Black;
  FastLED.show();
But I had  no luck. The ground of the power supply and board are connected. Several LEDs gave a flash when they were connected to power but they did not light. Am I missing any steps?
Actually, just after typing that I switched my power supply on and off and now several of the LEDs in the beginning of the strip are blue and some are green, though they aren't all in order - many aren't lit at all. It seems like turning the supply on and off changes the pattern. Sometimes three or four are blue, sometimes they're a mix and sometimes a bunch are green. It doesn't seem to follow a pattern as to which are lit.
MikeSch
I had been through these examples before but went through them again with no luck. Every program I run compiles and downloads fine with no result in the LED strip
ieee488
It is not the sketches. They work.
You need to check your connections.
MikeSch
I have been over the connections several times and cannot find the problem, though I do not have the equipment to do much at home at the moment. I'll have to review and maybe redo tomorrow.
For now, as per the diagram, I have the usb to computer, a power source for the board, digital pin 6 going to DIN, 5v power source going to the +5v pad, ground on the strip to both the board ground and the power supply ground.
Thank you for the site, I'll keep looking over the connections to find the problem
ieee488
I have the 5V power supply going to the Arduino and to the strip. I don't have the USB connected once the sketch has been uploaded but having it connected shouldn't be causing your problem.
5V power supply ground to the strip and to the Arduino.
Data from Arduino to Data on the strip.
Qdeathstar
post a picture of your connections.
mcnobby
Scope the DO output from the first WS LED in the string, if there is no data output when you are streaming data to it then the first LED has blown
I have found a few WS LEDs that fail and nothing lights from the blown LED onwards
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
MikeSch
Sorry for the delay. We have the setup remade and will attach a picture of the setup and the result of this code:
Code: [Select]
#define DATA_PIN 6
    //FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
  FastLED.show();
  FastLED.show();
Only three of the LEDs lit up after running the code and switching the power supply on and off. We still have the problem of different LEDs turning on each time the power is switched on and off.
Wawa
Grumpy_Mike
Quote
It is not a problem apart from the fact that you should not disconnect the LEDs power while the LED data signal is active as that can blow the first LED.
There is no common ground between the Arduino and your LED's power supply. Without one it will not work.
MikeSch
My apologies again for the delay I had to relocate everything to my house. I believe I have fixed the problem of the common ground (The board and strip are now both connected to the ground vertical of the breadboard). I ran the following code (same as above) with no result. The two LEDs that are white were lit that way when the power supply was first flipped on. Picture of setup is attached
Code: [Select]
#define NUM_LEDS 147
#define DATA_PIN 6
  FastLED.show();
  FastLED.show();
