Topic: Problem with Compilation (Read 572 times) previous topic - next topic
Mentoelektro
Can somebody tell me why the compilation process last for 10 minutes and longer? Even if I use a basic program from a list for example Blink...
I have 1.6.8 version.
Please help me :(
Coding Badly
Do not cross-post.  Other thread removed.
Coding Badly
sterretje
Compilation (verify) or upload? Which OS?
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
johnwasser
A bunch of people have had IDE 1.6.x problems, including IDE crashes and bizarre compile errors, when they had a previous 1.5.x/1.6.x installation.  At least some of those problems seem to be caused by out-of-date executables that the IDE saves outside the IDE installation directory.  Perhaps that is what is causing your particular problem.  In such cases it appears that the fix is to delete or rename the old "Arduino15" directory and re-install 1.6.x.
On Mac OS X:
/Users/(username)/Library/Arduino15
On Windows:
C:\Users\(username)\AppData\Roaming\Arduino15
On Linux:
/home/(username)/.arduino15    (a.k.a. ~/.arduino15)
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
DrAzzy
I've seen people complaining of really slow compile times for a while now. Nobody ever seems to have a concrete solution, but it definitely has a large impact on some users.
I'm not sure if it started with 1.6.6 (1.6.5r5 was the last good version - 6 and 7 had compiler problems, and 8 has a super nasty bug in serial handling), or existed before that.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
