Topic: Which cables and connectors for a diy projects? (Read 446 times) previous topic - next topic
wgh000
I'm looking for cables and connectors to use in a custom project. I'm going to print some boards but I'm not sure which cables and connectors is better to use.
How are you doing? Which cables and connectors you prefer to use and see as a better solution?
I know the answer depends on the number of cables and the type of sensors, you are using, but I am looking for idea to have projects stables and professional.
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
larryd
No technical PMs.
wgh000
Thank you Larry, so are you suggesting using utp cables and solder them in male headers?
larryd
Sometimes soldered wires are suceptible to breakage near the connector pin.
Crimp connectors with strain relief holding on the insulation is my preference.
When I make up cables I lean towards a multi conductor cable containing stranded wires.
You use male straight or right angle pins on the PCB and female on the DuPont connector.
No technical PMs.
wgh000
larryd
No technical PMs.
