Topic: Problems with piezo when using extenral batery (12 knock lock) (Read 949 times) previous topic - next topic
mateuy
I'm using the piezo as in "12 knock lock" project to read claps instead of knocks.
When I plug Arduino to the computer everything is fine.
If no sound I get values near to 0 form the piezo. I I clap I get higher ones.
However, if I use a "mobile charger" battery to charge Arduino my piezo sends values between 0~30 when no sound exists, and there is no way to detect claps.
Which can be the cause of this different behavoiur?
Thanks
arjan_hes
Check your battery.
- Maybe the voltage is a bit low.
- Can it supply enough amps to power the arduino (I guess that answer is a yes because it uses hardly any, but still).
- Is there a considerable drop in voltage when you power the arduino with it?
