Topic: 16x2 LCD Controlled by Serial (Read 443 times) previous topic - next topic
Mike44449
I got an idea to make a simple LCD that is controlled via a serial connection with a few simple commands to clear the display, display time since reset, etc.. So I made it, and I figured I would give it to the community, I have attached the circuit diagram below and I ask for no credit; take the code and do what you want with it. Enjoy!
Circuit and code file is attached below.
Code: [Select]
//Created: April 2, 2016 by Michael Pate (mike44449)
//I ask for no credit, do what you want with my code :)
//There is nothing in this circuit but a 16x2 lcd connected
//with the provided circuit.
//Include the library and the pins that its connected to.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//String to store what is put into the serial monitor.
String serialIn;
  //Setup a serial connection and initilize the LCD.
  lcd.begin(16, 2);
  //Display the commands to the user with the serial monitor.
  Serial.println("ENTER TEXT ABOVE");
  Serial.println("clear   - CLEAR TEXT");
  Serial.println("millis  - DISPLAY MILLIS SINCE RESET");
  Serial.println("millisCon  - DISPLAY MILLIS SINCE RESET UNTIL RESET");
  Serial.println("           WARNING: millisCon CANNOT BE STOPPED WITHOUT A RESET.\n\n");
  Serial.println("------------------------------");
  //Flash a command on the LCD for 2 seconds, then clear it.
  lcd.print("ENTER SERIAL");
  delay(2000);
  lcd.clear();
  //Put the buffer contents into the string.
  serialIn = Serial.readString();
  //If the string entered is a command (clear), then clear
  //the display and let the user know via serial.
  if (serialIn == "clear"){
    lcd.clear();
    Serial.println("LCD: TEXT ERASED");
    //delete the serial buffer.
    Serial.flush();
  //If the command was "millis", display the millis since reset.
  if (serialIn == "millis"){
    lcd.print(millis());
    Serial.println("CURRENT: MILLIS FUNC.");
    Serial.flush();
  //If they want to see a count-up of millis, use the command "millisCon."
  if (serialIn == "millisCon"){
    //It requires a reset becuase it enters an infinite loop.
    Serial.println("CURRENT: MILLISCON FUNC. -TO STOP, A RESET IS REQUIRED");
    for(;;){
      delay(150);
      lcd.clear();
  //If the string entered does not equal any known command, display it on serial and LCD.
  if (serialIn != "" && serialIn != "clear" && serialIn != "millis" && serialIn != "millisCon")
    lcd.print(serialIn);
    Serial.print("CURRENT: ");
    Serial.println(serialIn);
    Serial.flush();
I think computers are way cool, who else has tricked a rock into thinking by giving it lightning?!
