Topic: Protoboard Platform (Read 2487 times) previous topic - next topic
runaway_pancake
Apr 03, 2016, 07:46 pm Last Edit: Apr 03, 2016, 08:23 pm by Runaway Pancake Reason: pic link
I made this protoboard platform.  It makes staging experiments easier.
There's lots of real estate inside the project box (Serpac 071BK).
I'll get around to placing some screw terminals and so on, lots of room still on the exterior surfaces.
I used the Arduino box to hold the Arduino because I don't like the Arduino's 3-hole mounting.  It snaps smartly into the box.
I took pics with and without the top panel (lid). Things are more accessible without.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
proto-pic
Engineering Support team for Proto-PIC.co.uk
Proto-Pic
larryd
#2
Apr 09, 2016, 02:39 am Last Edit: Apr 09, 2016, 02:39 am by LarryD
Did something similar:
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
keeper63
Pretty cool looking, guys!
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
runaway_pancake
Very convenient for running the X10 Firecracker demo this morning, trucking around the house and so on (100%).
@dlloyd: good demo there, +1
@proto-pic, @crOsh: appreciate your notice
larryd
#5
Apr 10, 2016, 07:41 pm Last Edit: Apr 10, 2016, 07:59 pm by LarryD
Can you put wires etc. in the base?
Would you post a X10 sketch?
I am having trouble get replacement modules for our X10 collection.
Have you experimented with Insteon products and X10 code?
No technical PMs.
runaway_pancake
"Can you put wires etc. in the base?"
You mean the black box that everything is mounted to?  Sure.  It's empty in there right now, but I have plans for putting stuff inside [#1, one those 'ubiquitous' 5V SMPS, a panel jack and a lead out; #2) a couple of pushbuttons, and then...]
Here's my X10 sketch, just turning on/off...
I got the X10firecracker.h from Arduino Playground (as I recall) and the Firecracker modules from ebay just before Xmas.
Code: [Select]
#include <X10Firecracker.h>
  X10.init(11,12,1); // rts signal, dtr signal, bit delay
                       // RTS is DE9 pin 7,
                       // DTR is DE9 pin 4
                       // DE9 pin 5 is GND
                       // interface w/ C17's DE9-F
  pinMode(13,OUTPUT);  //  concurrent with on/off command
  delay(1500);
void Test()
  X10.sendCmd(hcA,7,cmdOn);
  digitalWrite(13, HIGH);
  delay(5000);
  X10.sendCmd(hcA,7,cmdOff);
  digitalWrite(13, LOW);
  delay(5000);
  Test();
I know nothing of Insteon.
larryd
Thank you for your sketch.
I have not used Insteon, but have been told their modules accept the X10 protocol.
Would have been nice to have had the room under my unit to store wires and a power supply :(
No technical PMs.
larryd
#8
Apr 10, 2016, 10:00 pm Last Edit: Apr 10, 2016, 10:11 pm by LarryD
What is the source for the clear Arduino box?
I made this front panel to a breadboard setup a while back.
Might want to consider a removable version attached to the back/front surface of your mounting box.
No technical PMs.
runaway_pancake
larryd
Complete with light pipes ;)
Thanks.
No technical PMs.
runaway_pancake
Made a digital thermometer this morning:
• LM34 temperature sensor
• charlieplexed BCD display
Tells me it's 74
larryd
Neat
I like DuPont connectors. :)
No technical PMs.
runaway_pancake
As used for some WS2812 test & eval recently.
Maybe you can make out the terminal block I've placed (but still not using, thinking).
runaway_pancake
Gone over deep into 'The Great Relay Board Mystery' --
