Topic: CNC shield with module relay (Read 2675 times) previous topic - next topic
ghomghom59
Hello friends : p
Well now I work with Arduino on a CNC machine and CNC shield wire I X and Y their works perfectly . ( I use G- code sender TO ORDER THESE Two Engines )
Whether the problem is the ax Z is command by a pneumatic energy ( Cylinders ELECTROVANNE ... ) Who are controllable relay WITH moduls relay
my question is Is That I can USE CNC my shield and Relay Module for Controler my ax Z. Knowing That relay is Powers by a voltage of 5 V.
I tried for the 5V connected / GND From CNC shield VCC / GND But nothing happened.
Robin2
You have not told us what CNC program you are using on your Arduino.
You have not posted a link to the datasheet for the CNC shield.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
ghomghom59
I think you can get information with this link...
Thank for your help
http://www.civade.com/images/grbl/Arduino-CNC-Shield-V3-Layout.jpg
Robin2
#3
Apr 06, 2016, 08:20 pm Last Edit: Apr 06, 2016, 08:20 pm by Robin2
Image from Reply #2 so we don't have to download it. See Image Guide
...R
Robin2
And what CNC program are you using?
...R
ghomghom59
I use Universal G-code sender it's work perfectly for X et Y ( control by motor) but for Z I use pneumatic energy?
How I can do this? I know that I need relays module for control hight energy but I don't know how I can Use that.
Robin2
I thought the GCode Sender was a program on a PC to send GCode to an Arduino?
If that is correct then there must be a program on the Arduino to interpret the GCode and make the motors move. That is the program we need to know about.
If I am wrong about the GCode Sender pleas post a link to its documentation.
...R
ghomghom59
In the arduino I use Grbl ( https://github.com/grbl/grbl ) the GRBL convert the G-code from G-code sender to arduino language.
Do you this I need change the one programm in grbl file ?
Robin2
Finally ...   :)
I reckon you need to put your question to someone who is familiar with GRBL - perhaps on one of the CNC Forums or on the RepRap Forum.
The Arduino Forum is primarily for helping people write their own programs.
...R
