Topic: Due IRremote library problem (Read 596 times) previous topic - next topic
Adaptex
Apr 07, 2016, 12:52 pm Last Edit: Apr 07, 2016, 01:25 pm by Adaptex
Hi guys,
I downloaded the IRremote library for the Arduino Due (it can be found here).
I ran an example program, but I got some errors:
Code: [Select]
C:\Users\ASUSRE~1\AppData\Local\Temp\builde5718c39b07e28d92e93ff17b7d9ef71.tmp\libraries\Arduino-IRremote-Due-master\IRremote2.cpp.o: In function `MATCH_SPACE(int, int)':
C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master/IRremoteInt2.h:213: multiple definition of `MATCH(int, int)'
C:\Users\ASUSRE~1\AppData\Local\Temp\builde5718c39b07e28d92e93ff17b7d9ef71.tmp\sketch\IRtest.ino.cpp.o:C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master/IRremoteInt2.h:213: first defined here
C:\Users\ASUSRE~1\AppData\Local\Temp\builde5718c39b07e28d92e93ff17b7d9ef71.tmp\libraries\Arduino-IRremote-Due-master\IRremote2.cpp.o: In function `MATCH':
C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master/IRremoteInt2.h:214: multiple definition of `MATCH_MARK(int, int)'
Multiple libraries were found for "IRremote2.h"
 Used: C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master
 Not used: C:\Program Files (x86)\Arduino\libraries\IRremote
C:\Users\ASUSRE~1\AppData\Local\Temp\builde5718c39b07e28d92e93ff17b7d9ef71.tmp\sketch\IRtest.ino.cpp.o:C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master/IRremoteInt2.h:214: first defined here
C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master/IRremoteInt2.h:215: multiple definition of `MATCH_SPACE(int, int)'
C:\Users\ASUSRE~1\AppData\Local\Temp\builde5718c39b07e28d92e93ff17b7d9ef71.tmp\sketch\IRtest.ino.cpp.o:C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master/IRremoteInt2.h:215: first defined here
collect2.exe: error: ld returned 1 exit status
Using library Arduino-IRremote-Due-master in folder: C:\Users\Asus Realsense\OneDrive\Documenten\Arduino\libraries\Arduino-IRremote-Due-master (legacy)
exit status 1
Error compiling for board Arduino Due (Programming Port).
Is there anyone who had the same problem and somehow fixed it? If so, I'd love to hear it.
Cheers,
Jeroen
