Try this slightly modded blink. Open the serial monitor and see if it tells you it's in setup() once then at the top of loop() each time through.
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model, check
the documentation at http://www.arduino.cc
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
Serial.println("in setup()");
// the loop function runs over and over again forever
Serial.println("in loop()");
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
