When using the following code, the temperature is ocassionally shown as 85, which I beleive is a fault code. The rest of the time the temperatures are OK. I am using parasitic mode with an 4.7 k pull up resistor. If I power the Vdd pin of the DS18S20, the readings are all ok.
I suspect it to be a timing problem, but where do I change the timing?
Somewhere in this forum, it has been mentioned, that an error exists with the "S" vesion of the DS18S20, but I have not been able to discover the nature of this error.
Any suggestions?
kind regards
Jens
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(sensors.getTempCByIndex(0));
