Topic: How to program a simple switch? (Read 2283 times) previous topic - next topic
lastchancename
I think the OP wants to pass some 'voltage' through the Arduino - using the pins as simple 'contacts' to his hoped-for Arduino 'relay'.
If that's the case - he's completely on the wrong track - and either needs an external relay & driver, or to approach the problem in a different way.
His swx (switch?) pins are assigned as OUTPUTS - so that's not a good start.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
ChrisTenone
This is the second time this weekend someone wanted to use a switch to connect one pin to the other. The other instance was on a steering wheel.
What, I need to say something else too?
larryd
Maybe we are missing something, if we could market the solution, we could make a million.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
JimboZA
#18
Apr 11, 2016, 07:23 am Last Edit: Apr 11, 2016, 07:23 am by JimboZA
If you want pin 5 to be in the same condition as pin 6, and you already have the wherewithal to control pin 6, why not just control pin 5 the same way.
But I'm probably missing something here, and as someone suggested already I suspect an XY problem here.
..... and that didn't end well ;)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
DARCCLLC
As aarg stated "You do realize that the Arduino has nothing like internal switches or analog multiplexers that you can assign to pins, right?"
I have worked with PLC's and did not realize that Arduino does not have internal switches.
Thanks for your time and patience.
I'll be looking for a STSP relay.
DARCCLLC
MalharD
And that guy posted 5 times...
-Malhar
Murphy always gets me ...
outsider
#22
Apr 11, 2016, 04:47 pm Last Edit: Apr 11, 2016, 04:48 pm by outsider
If the load that you're switching is small (less than 500mA) and non reactive, you may want to consider a reed relay. The coil draws only about 15mA and can be driven directly from an Arduino output pin, larger relays need an external power supply and driver like a transistor.
Check back in when you get your relay.
http://www.amazon.com/Opto-22-G4ODC5R-Normally-Isolation/dp/B00597VDBY/ref=sr_1_4?s=industrial&ie=UTF8&qid=1460384117&sr=1-4&keywords=reed+relay+module
http://www.opto22.com/site/pr_details.aspx?cid=4&item=ODC5R
DARCCLLC
Code: [Select]
                         int LED = 13;
const int rs12 = 12; //Reed Switch
const int sw9 = 9; //Tilt Switch
const int rb6 = 6; //Reset Button
int swV = 0; //Tilt Switch On or Off
int rbV = 0; //Reset Button On or Off
int rs12on = 0; //Reed Switch On or Off
{                           pinMode(LED, OUTPUT);
 pinMode(rs12, OUTPUT); //Pin 12 5vdc to Reed Switch
 pinMode(sw9, OUTPUT);  //Pin 9 Tilt Switch Output
 pinMode(swV, OUTPUT);  //Variable Switch Value
 pinMode(rb6, OUTPUT);  //Pin 6 Reset Button Output
 pinMode(rbV, OUTPUT);  //Variable Button Value
{                         digitalWrite(LED, LOW); //Keep LED Off
  rbV = digitalRead(rb6); //Makes rbV = Pin 6 value
  swV = digitalRead(sw9);  //Makes swV = Pin 9 value
  while (swV == HIGH)      //#1 Loop until this value becomes false
  if (rbV == HIGH)         //If Reset Button is pressed opens Reed Switch
  digitalWrite(rs12, LOW);  //Opens Reed Switch (rs12) Which dis-connects Solar LED to Solar Cell/Battery 1.2VDC
   } //If End
  while (rbV == LOW)       //#2 Loop until this value becomes false
  rs12on = digitalRead(rs12); //Makes led12on = Pin 12 value
  digitalWrite(rs12, HIGH);    //Closes Reed Switch (rs12) Which connects Solar LED to Solar Cell/Battery 1.2VDC
    }  //While #2 End
 } //While #1 End
} //Void End
Components:
5VDC Reed Switch, Tilt switch, Push button, 9V battery, 1.2V Solar Light (revised wiring) & Mini Prov 5V
Thanks for your help, I guess I eventually would have figured out the Arduino does not have internal switch capability.
Razz
outsider
Could you please post a drawing of your circuit and explain in detail what your project is supposed to do?
I'm still in the dark. :smiley-confuse:
JimboZA
But what on any of the product pages (like this one for Uno) would have given you the impression it did?
ChrisTenone
Razz
Of course it does! Transistors in a microprocessor are switches, and it's lousy with transistors in there. But just leave them alone - they know what to do. You want to use an external switch to send a signal to the Arduino that a button has been pressed (or a reed switch, tilt switch, etc.)
When you hook two wires (or pins, or whatever) together, you are creating a switch, even if you are using a paperclip to connect two pins. The simplest (and surprisingly effective) switch is wired so that one side of the switch goes to a pin, and the other to ground. In the sketch's setup code put in the line:
pinMode(pin, INPUT_PULLUP);
Then in loop, when you want to test the switch use:
buttonState = digitalRead(pin);
If the button is pressed, buttonState will be LOW. When it is released buttonState becomes HIGH. You can get fancier than this, but this is the basic method of using a switch with Arduino.
