Topic: Sending Weather Data (Multiple Values) between 2 Arduinos (433Mhz) (Read 1 time) previous topic - next topic
man1ac
Hey guys,
I am kind of the to the whole thing. Had C and some basic µC programming back in the university.
At the moment I am "learning" the basics and want to transfer Data between 2 Arduinos. The first step was some kind of tutorial from instructables, which worked perfectly fine.
Today I wanted to take the next step in sending 2 Values from a DHT22 to the 16x2 LCD. I somehow got it to work, altough I dont understand all the code.
Next step would be to add commas.
I understand I have to use floats instead of ints? But if I change the programm to float (sprintf(string1, "%f,%f", temp, hum); even the string1 shows just ?,?
I added my code, so maybe you understand my problem.
regards from germany
Bastian
AWOL
By default, sprintf doesn't support floats on the Arduino.
Try dtostrf
man1ac
Thanks! Tried that but I get:
"exit status 1
cannot convert 'char*' to 'double' for argument '1' to 'char* dtostrf(double, signed char, unsigned char, char*)'
I think I am missing some library? Could anyone give me an example on how my dtostrf would look like? The temp value has 4 digits, 2 after the decimal point)
AWOL
Posting an error message without the code it relates to is kind of pointless, don't you think?
Use code tags
man1ac
Cant tell sorry. I cant even use the dtostrf function (it does not get displayed orange.)
I changed the ints to floats and tfrom that on forward I dont know how to use the dtostrf function.
AWOL
If you don't tell us what you've tried, it's very hard to help you.
Quote
That means nothing at all - syntax highlighting is simply eye-candy.
man1ac
I've tried nothing so far and would like to get advice on how to transform a float to string.
But after I reloaded the programm again I get totally messed up results for the 2nd channel (hum). I get values around +-25000
AWOL
You could try using this
man1ac
Thanks!
Do I need some kind of special library for this?
Blue Eyes
This function is part of the standard library.  Try running the following.
Code: [Select]
char fBuff[20];        // buffer for converted float
float val = 3.39457f;  // float to convert
  // print with precision from 2 to 5
  for(int precision = 2; precision < 6; precision++)
    // print float with given precision, padded to 7 characters
    Serial.print("Precision = ");
    Serial.print(precision);
    Serial.print("  value = ");
    Serial.println(dtostrf(val,7,precision,fBuff));
man1ac
Thanks!
@AWOL: Hadnt had the chance of working on the project again. Will do so today!
@BLue Eyes: Thanks, this looks nice. Will test it!
For my example the output I sent (whats written into string) I want my 2 values in there.
My DHT22 sends 2 floats:
temp = 24.45°C (example)
hum = 45.60%
To convert temp into a string using dtostrf it would look like:
char string1[21]; //the one I want to send
char tempstring[10]
char humstring[10]
dtostrf(temp,6,1,tempstring); // The temp could have -10.04 (so 6 characters) and 1 character after the decimal point would be enough
dtostrf(hum, 5, 1, humstring);
sprintf(string1, "%s,%s," , tempstring, humstring)
This should produce a string that contains both values?!
On the receiving side I would need to seperate the 2 strings again and then convert them into floats?
sscanf(StringReceived, "%s,%s",&tempstring, &humstring);
sscanf(tempstring, "%f", &temp);
sscanf(humstring, "%f", &hum);
(Is it a correct use of sscanf? Or wrong in general?
AWOL
Code: [Select]
strcat instead of sprintf would be simpler, but I don't see why you need everything in one string.
"atof" or "strtod" are simpler than "sscanf"
man1ac
Thanks.
I dont know if I need everything in one string. I Simply dont know on how to send the values after one another. I think I could copy the sending line. But how do I receive them and save the first in "value1" and the 2nd in value two.
I thought having them in the same string would make things easier.
If can show me a neat way on how to send 2 values and display them simultaneously at my LCD - very much appreciated :)
swe-dude
Hello why send floats at all???
use the working code you have and just multiply the values with 100 on the transmitter side and then divide by 100.0 on the receiver side. much simpler :)
