Topic: How to flash genuine HM-10 firmware on CC2541 (make genuine HM-10 from CC41) (Read 119512 times) previous topic - next topic
rey8801
Here the rest of the pictures. Too many for a single post.
rey8801
#106
May 26, 2018, 02:06 am Last Edit: May 26, 2018, 02:07 am by rey8801 Reason: Add picture
Last one I swear  :smiley-lol:
rey8801
Up...
If someone got it worked with my same hardware, please share the trick...
Thx!
rtek1000
Hi, guys,
I was successful.
Thank you very much!
You who put 5V directly are very crazy! Or very brave!
I put a 1k resistor between the Arduino and the HM-10.
Now the site has firmware version 603, someone tried to upgrade?
[HM-10 HM-11 firmware V603 released (2017/11/14 10:44:51)]
My antivirus blocked the download:
http://www.jnhuamao.cn/rom/HMSoft-10-2541-V603.zip
---> HMSoft-10-2541-V603.zip\HMConfigAssistant.exe Win32:Malware-gen <---
Some online antivirus are reporting viruses as well:
https://www.virustotal.com
Please avoid private messages, your question may be someone's answer in the future!
rtek1000
The v603 did not work here!  :'(
The CCLoader.exe program shows the CC2540 chip.
The PDF document provided by the manufacturer says that the CC2540 chip is not the same as the CC2541, maybe the v603 firmware is for the CC2541 chip.
Due to the problem with antivirus, I could not follow the method described by the manufacturer, I used CCLoader, and after v603 I turned the v540.
The strange thing is that the site shows the details of the board with the firmware: V605, and download has only v603.  ???
Note: When opening the port the Arduino Nano was reset, so I waited about 3 seconds and tried again (CTRL+C --> "^C"). In this way began the progressive counting of blocks, arrived at 512 for v540, and a little less for v603
For v540:
Quote
D:\Arduino\Bluetooth\Flash>CCLoader.exe 2 Firmware.bin 0
Copyright (c) 2013 RedBearLab.com
CCLoader.exe version 0.5
Comport : COM2
Bin file: Firmware.bin
Device  : Default (e.g. UNO)
Comport open!
<Baud:115200> <data:8> <parity:none> <stopbit:1> <DTR:off> <RTS:off>
File open!
Block total: 512
Enable transmission...
Request sent already!
* If there is no respond last for 3s, please press "Ctrl+C" to exit!
* And pay attention to :
*   1. The connection between computer and Arduino;
*   2. The connection between Arduino and CC2540;
*   3. Whether the device you using is Leonardo or not;
*   4. Other unexpected errors.
Waiting for respond from Arduino...
^C
Comport : COM2
Comport open!
File open!
Block total: 512
Uploading firmware...
1  2  3  4  5  6  7  8  9  10  11  12  13  14  15  16  17  18  19  20  21  22  2
3  24  25  26  27  28  29  30  31  32  33  34  35  36  37  38  39  40  41  42  4
3  44  45  46  47  48  49  50  51  52  53  54  55  56  57  58  59  60  61  62  6
3  64  65  66  67  68  69  70  71  72  73  74  75  76  77  78  79  80  81  82  8
3  84  85  86  87  88  89  90  91  92  93  94  95  96  97  98  99  100  101  102
  103  104  105  106  107  108  109  110  111  112  113  114  115  116  117  118
  119  120  121  122  123  124  125  126  127  128  129  130  131  132  133  134
  135  136  137  138  139  140  141  142  143  144  145  146  147  148  149  150
  151  152  153  154  155  156  157  158  159  160  161  162  163  164  165  166
  167  168  169  170  171  172  173  174  175  176  177  178  179  180  181  182
  183  184  185  186  187  188  189  190  191  192  193  194  195  196  197  198
  199  200  201  202  203  204  205  206  207  208  209  210  211  212  213  214
  215  216  217  218  219  220  221  222  223  224  225  226  227  228  229  230
  231  232  233  234  235  236  237  238  239  240  241  242  243  244  245  246
  247  248  249  250  251  252  253  254  255  256  257  258  259  260  261  262
  263  264  265  266  267  268  269  270  271  272  273  274  275  276  277  278
  279  280  281  282  283  284  285  286  287  288  289  290  291  292  293  294
  295  296  297  298  299  300  301  302  303  304  305  306  307  308  309  310
  311  312  313  314  315  316  317  318  319  320  321  322  323  324  325  326
  327  328  329  330  331  332  333  334  335  336  337  338  339  340  341  342
  343  344  345  346  347  348  349  350  351  352  353  354  355  356  357  358
  359  360  361  362  363  364  365  366  367  368  369  370  371  372  373  374
  375  376  377  378  379  380  381  382  383  384  385  386  387  388  389  390
  391  392  393  394  395  396  397  398  399  400  401  402  403  404  405  406
  407  408  409  410  411  412  413  414  415  416  417  418  419  420  421  422
  423  424  425  426  427  428  429  430  431  432  433  434  435  436  437  438
  439  440  441  442  443  444  445  446  447  448  449  450  451  452  453  454
  455  456  457  458  459  460  461  462  463  464  465  466  467  468  469  470
  471  472  473  474  475  476  477  478  479  480  481  482  483  484  485  486
  487  488  489  490  491  492  493  494  495  496  497  498  499  500  501  502
  503  504  505  506  507  508  509  510  511  512  Upload successfully!
File closed!
Comport closed!
rtek1000
Now the Firm v603 has worked as IBEACON:
(P.S.: AT+VERR? and AT+VERS? shows HMSoft V604, Bug?)
1: Install the V540 with CCLoader.exe
2: Upgrade to V603 with HMSoft.exe
After upgrading the firmware, run the AT commands via serial port:
Quote
1. AT+RENEW Restores factory defaults
2. AT+RESET Reboot HM-10
3. AT Wait for OK
4. AT+MARJ0x1234 Set iBeacon Major number to 0x1234 (hexadecimal)
5. AT+MINO0xFA01 Set iBeacon Minor number to 0xFA01 (hexadecimal)
6. AT+ADVI5 Set advertising interval to 5 (546.25 milliseconds)
7. AT+NAMEDOPEY Set HM-10 module name to DOPEY. Make this unique.
8. AT+ADTY0 Advertising ScanResponse, Connectable
9. AT+IBEA1 Enable iBeacon mode
10.AT+DELO1 iBeacon Allowed to broadcast and scanning
11.AT+PWRM1 Don't auto sleep
12.AT+RESET Reboot
Look this:
http://www.instructables.com/id/make-iBeacon/
rtek1000
I tried slave mode and managed to pair with a smartphone, and I was able to send data through the UART serial port, but I could not make the system LED blink, does anyone know how to do it?
I already checked the LED with a multimeter, it turns on and is properly connected to the HM-10 pin
I already tried the command:
Quote
AT+PIO10 Set PIO1 output status (System LED)
Unconnected Output: 500ms High 500ms Low,
Connected output: High
To be able to pair with the smartphone:
(Of course the Smartphone must be compatible with Bluetooth LE [BLE: Low Energy])
Quote
AT+RENEW
AT+RESET
AT+TYPE3 Set Module Bond Mode: Auth with PIN
Default PIN: 000000
To monitor connections:
Quote
AT+NOTI1 Set notify information: Notify
Link ESTABLISHED:
OK+CONN string through UART
Link LOSTED:
OK+LOST string through UART
AT+NOTP1 Set notify mode with address
OK+CONN:001122334455 String "001122334455" is the MAC address string
Quote
It not works like other simple Bluetooth module like HC-05 and HC-06
Source: https://forum.arduino.cc/index.php?topic=377228.0
rtek1000
I found out what happened that the system LED did not blink,
I made a big mistake,
I soldered all the pins of the HM-10 on the daughter board.  :-[
The daughter board has pin connection 24 and 31, so when I soldered, these pins stayed connected, as the pin 31 should be pulling down, the LED does not light up.
I realized this after monitoring the voltage the LED was receiving, it was only 0.006V (6mV), so I tested the continuity.
Fortunately on the daughter board has a track under the board, which makes this connection of these pins, so I had to cut it, and the LED came back to flash.  :smiley-sweat:
gta12027
I Followed this routine that make cc-41A(Fake board) to HM-10.
but I have a problem with AT command....
it doesn't work....
before I upload the binary file cc2541hm10v540, the AT commands worked
Now the Led on the board is blinking faster than before.
I have many fake board so I tried to upload by CCLoader.exe several times
How can I figure it out?....
I checked RX, TX Line swipping, and version 550 bin file....
mariocaptain
murcha
BTW, the latest versions of the firmware can be downloaded here http://www.huamaosoft.com/download_rom.asp?id=
axizozuk
What application should I use when connecting with my mobile phone? I do not accept 000000 as my PIN. 123456 accepts and connects. but the android applications do not connect properly? What is the reason?
rsvsaha
Today at 06:49 pm
Hii... I faced a peculiar problem while trying to configure my AT-09 BLE Device's baud rate. I used the AT+BAUD2 which has set it to a baud rate of 2400 but now when I run any AT+ Command it prints ERROR twice on the console. But when I just use AT to check the connection the device returns ok. What might be the cause of this problem can anyone please help?
Jocoyo
I have been trying to use your guide but I have not been able to do it on my Mac. Do you know what is the command in the terminal?
