Hi, I make the update to HM-10 firmware using the main tutorial, now I connect using Android, that now show the name "HMSoft", but for some reason that I don't know, is very hard to make "AT" command work, before a lot of trying sometimes this work, but just respond with OK for all command i try to send.
For sample, if I send "AT+NAMETest" they return "OK" but don't change de name and nothing change.
If I try another commands, the same result, just return "OK".
Someone have the same problem?
What can I do to fix it?
I will try re-flashing to see if this work well.
UPD: I try again re-flashing and nothing, the same situation my Android connect but I can't send or receive commands and any "AT" command work. Now I don't receive any OK.
