Topic: Using analog RGB individually addresable LED strip without a moffset (Read 946 times) previous topic - next topic
UltiFix
Can this be done using analog or pwm ports on a cheapduino?
It's an analog individually addreseble led rgb strip of 60 led's.
Thanks!
-Sam
septillion
Short answer, no. You need a MOSFET or a relay. You cannot dim with a relay.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
MarkT
1) No part number or datasheet - no information to go on at all.
2) Individually addressable LEDs are _not_ analog, and MOSFET is not needed to drive a serial signal
used in individually addressable LEDs.
So please produce accurate information about the actual LED strip you have.
septillion
Mm, you guys are right. A link to the ledstrip would help (or a better explanation).
When I read analog RGB strip I just thought of a logic-less 5050 ledstrip. But then "individually addressable" doesn't make sens. And for a Neopixel the word analog doesn't make sens...
UltiFix
Iv used arduino in the past, but don't know a ton about leds... (Obviosuly)
Here is the datasheet https://www.adafruit.com/datasheets/WS2812B.pdf
Thanks!
-Sam
CrossRoads
Find the Neopixel library at adafruit.com
WS2812B is combined 3 LEDs and 8-bit PWM output per LED chip. You shift in 24 bits, pause, and it updates its outputs.
If you shift in more bits, its passes them along, and when shifting stops each devices uses the last 24 bits it received.
UltiFix
Got it working with the strand test, Thanks!!!
septillion
Btw, 60 leds needs a separate power supply. The USB power from a PC is not enough and the 5V out of the Arduino when powering the Arduino from anything else then 5V is not going to last.
