Topic: Impedance matching 4ft of 20awg wire (Read 4033 times) previous topic - next topic
Qdeathstar
Hello,
I am powering a long strip (50m) of ws2801 strips. About once an hour (but not on a schedule) I have a "blink" from my strips. It is annoying, so I've tried various things to silence them.
I installed filtering caps, and that seemed to make a difference.
I also removed a ground loop just tonight, and it seems like I might have gotten it down to once every two hours... but it's still there.
I installed 100ohm resistors between the controller and data, but now I've read that 100ohm is for cat5 cable's impedance and that other types of cable need difference resistor values based on impedance. I'm not sure if it will solve the blink or not, but I'm willing to give it a shot.
How can I calculate the impedance of 20awg copper?
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
DVDdoug
Quote
You can probably look-up the impedance for networking cable (CAT 5, etc.), but it depends on "construction".   That is, the space between the wires, etc.     And, I don't think it's an issue at 4 feet and at the data-rates you're working with.
It's probably not an impedance issue.    It could be software, or you may need to slightly slow-down the clocking.    (If you're using shiftOut() I'm not sure how to slow it down.)
When I had a problem with a shift register type interface, it turned out to be a noisy/marginal power supply.   And in my case, a larger capacitor on the voltage regulator for the LED driver stabilized the display.
With 50m of LED strips, you may have a power supply related issue too.
Wawa
Curious how you have powered 50meters of digital LED strip (post a diagram).
Shouldn't you power that at least 2-3meters or so.
Leo..
Boardburner2
Leo..
Depends on illumination levels.
Guide i saw was every metre.
Boardburner2
#4
Apr 16, 2016, 09:24 am Last Edit: Apr 16, 2016, 09:26 am by Boardburner2
Hello,
Have you tried a terminating resistor at the far end ?
Not sure if its needed though as the signal regenerates each pixel i think.
Some caps on the supply rails may help
OldSteve
..... or you may need to slightly slow-down the clocking.    (If you're using shiftOut() I'm not sure how to slow it down.)
It's not hard to override 'shiftOut()' by copying the function into the sketch file and introducing a delay between bits and/or between taking the clock high then low again.
It's a very simple function:-
Code: [Select]
void shiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, uint8_t val)
    uint8_t i;
    for (i = 0; i < 8; i++)
        if (bitOrder == LSBFIRST)
            digitalWrite(dataPin, !!(val & (1 << i)));
            digitalWrite(dataPin, !!(val & (1 << (7 - i))));
        digitalWrite(clockPin, HIGH);
        digitalWrite(clockPin, LOW);
Please do not PM me for help. I am not a personal consultant.
And others will benefit as well if you post your question publicly on the forums.
Boardburner2
Hello,
Do you have the option of trying it powered by batteries ?
In the past i have used a 6V LA cell as a 'capacitor' to fault find troublesome supplies.
Qdeathstar
#7
Apr 16, 2016, 01:45 pm Last Edit: Apr 16, 2016, 01:49 pm by Qdeathstar
I have it powered every four meters. I am using one 100amp server supply. I don't think power is nessarily an issue (at full brightness everthing is bright white, not yellow). I have installed a line filter on the mains side of the transformer and 100uf capacitors everywhere I inject power to the strips. I am going to install ferrites there as well.
I think powering it it off of batteries would require a lot of batteries.
where would the terminating resistor go? what value? I hear something about a 1k between data and clock, but I didn't trust the source. I am using FastLED and have slowed down the data rate to 1mhz.
I notice that when I turn on mains powered light fixture closer to the strip, I get a blink.
Boardburner2
That would imply its an interference problem.
Perhaps moving the strip away from any electrical sources would narrow it down.
In #4 i mentioned caps, i meant distributed along the strip.
50 m long makes a good aerial, distributed caps across the rails may help
Qdeathstar
#9
Apr 16, 2016, 02:52 pm Last Edit: Apr 16, 2016, 03:09 pm by Qdeathstar
Should I put the caps voltage to ground? I'd need a axial cap like a resistor because there is not a lot of room in my aluminum channel. Maybe I should ground the channel (not to psu ground but to earth)
I can post a time lapse video of the blink it that will help.
Terminating resistor sounds like a easy thing to try. Could you elaborate on that
Boardburner2
#10
Apr 16, 2016, 03:38 pm Last Edit: Apr 16, 2016, 03:49 pm by Boardburner2
I was thinking Supply to ground, just an idea though.
Don't think it will make a difference , i made an incorrect assumption initially.
The signal gets regenerated each led.
Do they blink when steady state ? Ie with no spi signals sending.
EG turn them on then disconnect the spi and clock signals.
Simpler test than soldering a load of caps.
100 uF implies electrolytic.
I was thinking of something with a low ESR, 1uF ceramic or similar.
MarkT
50m of anything is going to pick up a lot of interference, You probably need to to electrically break up
that long string to reduce the interference, which really means treating as a set of shorter strips and
driving each separately / in parallel.
But then you have to synchronize each portion of course.
Is the run one long straight run?  That's probably at risk of damage in the next thunderstorm if so too
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
Boardburner2
#12
Apr 16, 2016, 04:24 pm Last Edit: Apr 16, 2016, 04:26 pm by Boardburner2
I am struggling to understand the mechanism.
For all the leds to blink at once.
They are all independently controlled local to the LED.
I wonder if the chips have some sort of reset internally i do not know about.
Qdeathstar
#13
Apr 16, 2016, 05:54 pm Last Edit: Apr 16, 2016, 05:55 pm by Qdeathstar
One chip boosts the signal of the next chip so I'm assuming
Any way around that.
Quote
Are there solutions for this? It's not all in a strait run. 10m max straight run. I had 10m set up outside before for about a year, and it was still going strong.. Even after severe weather/hurricanes.
Qdeathstar
I would still like to try it. Someone said it worked well for them, but there wasn't enough detail. 1k across data and clock is what the said, but is that across one another or to ground?
Quote
I haven't tested this. But if I set up the LEDs to only get written once in setup, will that achieve the same thing?
Quote
I will try some of those as well.
