Topic: Wifi AP? (Read 1 time) previous topic - next topic
Smebdy
I'm currently trying to setup the MKR1000(contest unit) and have used the Wifi101 AP example. It shows the network, but says no internet as well as when I go to the IP, chrome gives an error. I'm using windows 10 with Google Chrome. If you have an answer, please tell me.
AndreaRichetta
#1
Apr 18, 2016, 10:11 am Last Edit: Apr 18, 2016, 10:31 am by AndreaRichetta
seems a windows related issue, like firewall or something similar.
it's normal that it says no internet, because the MKR1000 doesn't act as a gateway to the internet .
the connection from the PC to the MKR1000 works?
if you open the terminal you should see the IP address of the board, you should see a reply like :
Access Point Web Server
Creating access point named: MKR1000-network
SSID: MKR1000-network
IP Address: 192.168.1.1
signal strength (RSSI):-100 dBm
To see this page in action, open a browser to http://192.168.1.1
If you try to open that ip 192.168.1.1, on serial console you see the reply (my case is chrome on OSX)
new client
GET / HTTP/1.1
Host: 192.168.1.1
Connection: keep-alive
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.87 Safari/537.36
Accept-Encoding: gzip, deflate, sdch
Accept-Language: it-IT,it;q=0.8,en-US;q=0.6,en;q=0.4,ja;q=0.2
client disconnected
new client
GET /favicon.ico HTTP/1.1
Host: 192.168.1.1
Accept: */*
Referer: http://192.168.1.1/
client disconnected
Example used : https://www.arduino.cc/en/Tutorial/Wifi101SimpleWebServerWiFi
Smebdy
I can't try it right now, but I will. But if it's firewall?
Samixx
#3
Jul 10, 2019, 01:22 pm Last Edit: Aug 28, 2019, 11:30 pm by Samixx
new client
GET / HTTP/1.1
Host: 192.168.1.1
client disconnected
new client
Host: 192.168.1.1
Accept: */*
client disconnected
192.168.1.1 doesn't work for me, I have reset my router but the page doesn't load.
I have followed the instructions mentioned here https://192-168-1-1ip.mobi/ but there is no results.
What shall I do ?
