Topic: Running multiple motors on one arduino for a walker robot (Read 892 times) previous topic - next topic
FoxBlade
Hi! I was working on making a walker robot, got all of the parts built and put together, then stopped and realized that the arduino might have a hard time controlling 4 motors at once. Is there a special trick to doing this, or can it simply not be done?
Thanks!
AWOL
Quote
Why would you think that?
FoxBlade
AWOL
I've run twice that many servos, and it worked perfectly.
jremington
The Arduino can control several motors or servos, but cannot provide power for any. Always use a separate motor/servo power supply and connect the grounds together.
FoxBlade
I'm sorry- I'm new to arduino- would I use a relay? How would I do that?
AWOL
Quote
If all you want to do is turn the motor on or off, or possibly reverse it, yes.
Not so good for speed control.
jremington
Quote
Do what?
For high quality but inexpensive motor drivers, check Pololu's offerings.
groundFungus
#8
Apr 23, 2016, 11:06 pm Last Edit: Apr 23, 2016, 11:07 pm by groundfungus
Do you want just on and off, speed control in one direction or speed control with forward and reverse? What is the stall current of the motors?  What is the rated voltage of the motors.  Are they steppers, brushed or brushless?  All of the details are important for choosing  driver for the motors.
