Topic: Arduino uno replaced by MKR1000 (Read 1 time) previous topic - next topic
FDemme90
Hello,
after replacement the test sketchis slower as before.
before: Arduino UNO R3
after: Arduino MKR1000
sketch: Adafruit HX8357 Libary : graphicstest
https://www.adafruit.com/products/2050
what is wrong?
thanks
AWOL
westfw
#2
Apr 28, 2016, 10:04 pm Last Edit: Apr 28, 2016, 10:11 pm by westfw
Probably something is going wrong with the setting of the SPI clockrate.
Are you using the Hardware SPI pins? (or do you think you are?)
In any case, SPI is likely to be the bottleneck, and the way I read the demo it will use the same speed SPI connection regardless of platform, so I'd expect them to be "approximately equivalent" (if nothing is broken.)
FDemme90
Hello,
i use the hardware SPI pins.
MKR 1000
10 - MISO; 9 - SCK; 8 - MOSI; CS - 4; DC - 5
Thanks
cbxbiker61
Adafruit graphics libraries are not optimized for Zero/MKR boards, whereas they do have some optimizations for AVR chips.  With better libraries the Zero/MKR will outperform the AVR boards by a bit.
FDemme90
Hello,
So you think that the problem isnt the SPI clock?
(How can i raise the SPI clock?)
Which lib is better in this combination? (MKR1000 & HX8357)
thanks for your help
FDemme
