Topic: [SOLVED]Arduino Leonardo/Yùn 38 kHz carrier  (Read 1 time) previous topic - next topic
zeroG
Apr 29, 2016, 03:16 pm Last Edit: May 01, 2016, 08:57 pm by zeroG
Hi guys,
i'm trying to generate a 38 kHz carrier signal to modulate an IR led. I succesfully tried with an Arduino Uno with the following code:
Code: [Select]
 #define pwmPin 11
 // toggle on compare, clk/1
 TCCR2A = _BV(WGM21) | _BV(COM2A0);
 TCCR2B = _BV(CS20);
 // 38kHz carrier/timer
 OCR2A = (F_CPU/(IR_CLOCK_RATE*2L)-1);
 pinMode(pwmPin, OUTPUT);
Obviously it doesn't work on my Arduino Yùn (which has the same Leonardo uC Atmega32u4). How should i change the code? I have never used this kind of notation and i can't understand the meaning of each command (i took a look at the datasheet but it's very hard to decode for me).
Thank you!
AnalysIR
The Leonardo/Yún/Atmega32u4 does not have a Timer2 which you are using in your, code.
I suggest you check out how it is done in the IRremote library.
https://github.com/z3t0/Arduino-IRremote/blob/master/IRremoteInt.h
Search for the use of Timer4 in the file linked above - which outputs the signal on pin 10 by default .
You could also look into the TimerOne library.
Visit our IR Remote Control Blog and Infrared RC for Air Conditioners
KontroLIR: 100% Arduino compatible IR Remote Control
LearnIR: Most advanced IR Learner USB Dongle
zeroG
#2
May 01, 2016, 03:50 pm Last Edit: May 01, 2016, 03:51 pm by zeroG
Thank you AnalysIR, i find in the library the Atmega32u4 part. I made a very simple substitution of the parameters name like this:
Code: [Select]
  #define pwmPin 10
  TCCR4A = _BV(WGM40) | _BV(COM4A1);
  TCCR4B = _BV(CS40);
  OCR4C = (F_CPU/(IR_CLOCK_RATE*2L)-1);
I'm going to try this code tonight, stay tuned!
zeroG
Problem solved!
I followed another way to obtain what i need. You can find the solution at the third post in this topic: http://forum.arduino.cc/index.php?topic=247926.0
Bye!
AnalysIR
For the benefit of others, it might be useful to post the actual solution that worked for you (i.e. code).
zeroG
#5
May 02, 2016, 12:22 am Last Edit: May 02, 2016, 12:24 am by zeroG
Of course!
1 - Download and install this version of PWM library: link PWM Leonardo
2 - If you want some examples, you can find them inside this older version of the library (copy only the examples!) : older version
3 - If you want to produce a continuous 38 kHz carrier (pwm @ 50% duty cycle) use this code in the setup() :
Code: [Select]
  #define pwmPin 10
  #define frequency 38000
  void setup(){
      //initialize all timers except for 0, to save time keeping functions
      InitTimersSafe();
      //sets the frequency for the specified pin
      bool success = SetPinFrequencySafe(pwmPin, frequency);
      pwmWrite(pwmPin, 128);
