the LED does not go out, it duels a bit but that is it, i did increase the 220R but made no difference?
This circuit detects mains AC (detects in the radio sense, rectifies and amplifies), so that the current
through the 220R load is pulsed, which the size and length of the pulses increasing as the copper
strip picks up more stray field. This means that most of the time the output transistor is off, so
that simply complementing the output won't work well.
You would need to low-pass filter the output voltage, then use a comparator to threshold the signal,
then drive an LED to get the inverted sense (light only when little input, no light when strong input).
[ Its probably possible to add low pass filtering earlier on in the circuit by adding a capacitor to
one of the transistor bases, that might help ]
