Topic: Turbidity sensor coding (Read 24146 times) previous topic - next topic
robywhite
How to write turbidity sensor coding for arduino??can someone help me..
Koepel
#1
May 06, 2016, 06:01 am Last Edit: May 06, 2016, 06:02 am by Koepel
They are 12 euros at AliExpress.
G = GND
A = analog output
D = digital output, the switching point is set by the potentionmeter.
V = 5V, 30mA
Use a 5V arduino board, and read the analog signal. Try the sensor in clear and dirty water and see what values you get for the analog value.
zhomeslice
hook you Analog output form the sensor to Arduingo A0 and Ground to G provide power, open up a serial monitor at 9600 Baud and you should be able to see what is being sent with this code:
output should read somewhere between 0 ~ 1024 on the serial display
Code: [Select]
  AnalogReadSerial
  Reads an analog input on pin 0, prints the result to the serial monitor.
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
 This example code is in the public domain.
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // print out the value you read:
  Serial.println(sensorValue);
  delay(1);        // delay in between reads for stability
HC
mcarmona
I am using one of these sensors for teaching purposes, and  I considered that:
1. The output voltage (Vout) of the sensor is inversely proportional to turbidity, so,
2. The clear water have a 0% turbidity, and
3. Turbidity of 100% means a fully opaque object,
So, I proposed the following equation for turbidity (in relative percent units):
Turbidity = 100 - (Vout/Vclear)*100
I also incorporated a push button to calibrate de sensor with clear water, in order to get Vclear (output voltage for clear water). I also used EEPROM library to store and recover the last calibration Vclear value in ROM.
Here is the full sketch:
#include <EEPROM.h> // to store last calibration value (blanco, Vclear)
#include <Wire.h>  // for LCD display (with I2S interphase)
LiquidCrystal_I2C lcd(0x3F,2,1,0,4,5,6,7,3, POSITIVE);
int sensor = 0; // variable for averaging
int n = 25; // number of samples to average
int sensorValue = 0;
float voltage = 0.00;
float turbidity = 0.00;
float Vclear = 2.85; // Output voltage to calibrate (with clear water).
int buttoncalib = 2;  // The pin location of the push sensor for calibration. Connected to Ground and
// pin D2.
int pushcalib = 1;  // variable for pin D2 status.
  pinMode(buttoncalib, INPUT_PULLUP); //initializes digital pin 2 as an input with pull-up resistance.
 // LCD display
  lcd.begin (16,2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Turbidity Sensor");
//Serial display
  Serial.println("Hi... welcome to your turbidity sensor");
  EEPROM.get(0, Vclear);  // recovers the last Vclear calibration value stored in ROM.
  delay(3000);  // Pause for 3 seg
pushcalib = digitalRead(2);  // push button status
if (pushcalib == HIGH) {
// If the push button is not pushed, do the normal sensing routine:
      for (int i=0; i < n; i++){
      sensor += analogRead(A1); // read the input on analog pin 1 (turbidity sensor analog output)
  delay(10);
  sensorValue = sensor / n;    // average the n values
  voltage = sensorValue * (5.000 / 1023.000); // Convert analog (0-1023) to voltage (0 - 5V)
  turbidity = 100.00 - (voltage / Vclear) * 100.00; // as relative percentage; 0% = clear water;
  EEPROM.put(0, Vclear); // guarda el voltaje de calibración actualmente en uso.
          // Serial display
          Serial.print(sensorValue);
          Serial.print(", ");
          Serial.print(voltage,3);
          Serial.print(", ");
          Serial.print(turbidity,3);
          Serial.print(", ");
          Serial.println(Vclear,3);
  // Display LCD
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Volts=");
  lcd.print(voltage,2);
  lcd.setCursor(0,1);
  lcd.print("Turbidity=");
  lcd.print(turbidity,2);
  lcd.print("%");
  sensor = 0;   // resets for averaging
// Calibration routine, when push button is pushed:
  Serial.println("Put the sensor in clear water to calibrate...");
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Calibrating...");
  delay(2000);
      sensor += analogRead(A1); // read the input on analog pin 1:
      delay(10);
  Vclear = sensorValue * (5.000 / 1023.000); // Converts analog (0-1023) to voltage (0-5V):
  sensor = 0;
  EEPROM.put(0, Vclear);  // stores Vclear in ROM
  lcd.clear();
  delay(1000);  // Pause for 1 seconds.  // sampling rate
gabriel_stone1717
Thanks mcarmona. The code works well and accurately!
johnwasser
Turbidity sensors measure scattered light, not transmitted light.  These units are primarily for washing machines and dishwashers to sense when the rinse cycle is "complete".
Looks like the Chinese "TSW-20" is a clone of the Thermometrics TSW-10:
https://www.amphenol-sensors.com/en/component/edocman/218-thermometrics-turbidity-sensors-tsw-10-datasheet/viewdocument?Itemid=8483
One really odd thing: the schematic of the TSW-10 sensor in the datasheet shows that it has three pins, none of which is Ground?!?  The schematic shows that Pin 1 is +5V, Pin 2 is the output, and Pin 3 is the cathode of the LED.  Pin 2 has a 4.7kOhm resistor to Ground and Pin 3 has a 470 Ohm resistor to Ground.
My guess is that they drew the schematic wrong and that Pin 3 is Ground instead of the cathode of the LED.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
gabriel_stone1717
#6
Sep 11, 2019, 05:08 am Last Edit: Sep 25, 2019, 10:52 am by gabriel_stone1717
I searched alot and found out the best turbidity sensor for arudino
https://www.ebay.com/itm/254255260517
It has sufficient documentation and sample code. Quick plug and play for my garden monitoring project.
Im happy! Thanks for all the info guys
mjwatkins
mcarmona - A button for calibration is mentioned. What kind of button is used and how is it connected?
// pin D2.
 // LCD display
  lcd.begin (16,2);
  lcd.clear();
  lcd.setCursor(0,0);
//Serial display
  delay(10);
          // Serial display
          Serial.print(", ");
          Serial.print(", ");
          Serial.print(", ");
  // Display LCD
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("%");
  lcd.clear();
  lcd.setCursor(0,0);
  delay(2000);
      delay(10);
  sensor = 0;
  lcd.clear();
murat229
Thanks a lot, can you also share the schematic of the system or just for the sensor without LCD display pls?
