Hi everyone I've managed to work it perhaps not the most straight forward way, however i would like all three servos to move at once now (next baby step!). any suggestions would be helpful!
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN 200 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 590 // this is the 'maximum' pulse length count (out of 4096)
Serial.println("16 channel Servo test!");
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
yield();
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= 60; // 60 Hz
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000;
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
pwm.setPWM(0,1000, 1500);
pwm.setPWM(0,2000,3000);
pwm.setPWM(1,1000, 1500);
pwm.setPWM(1,2000,3000);
pwm.setPWM(2,1000, 1500);
pwm.setPWM(2,2000,3000);
}[code]
