Topic: Multiplex 30 input 30 output (Read 311 times) previous topic - next topic
cowcowkiller
May 15, 2016, 06:57 am Last Edit: May 15, 2016, 03:34 pm by cowcowkiller
i trying multiplex between arduino mega using RS485 i succeed turn 1 output with 1 input
but now the problem i need turn an array of input through rs485 to output
MASTER
Code: [Select]
/*-----( Import needed libraries )-----*/
#include <SoftwareSerial.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define SSerialRX        10  //Serial Receive pin
#define SSerialTX        11  //Serial Transmit pin
#define RS485Transmit    HIGH
#define RS485Receive     LOW
#define Pin13LED         13
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX
int byteReceived;
int byteSend;
byte buttons[] = {22, 24, 26, 28, 30, 32, 34, 36, 38};
#define NUMBUTTONS sizeof(buttons)
byte lastStates[sizeof(buttons)];
int buttonState = 0;         // current state of the button
int lastState = 0;     // previous state of the button
void setup()   /****** SETUP: RUNS ONCE ******/
 // Start the built-in serial port, probably to Serial Monitor
 Serial.println("Error Checking ");
 pinMode(Pin13LED, OUTPUT);
for (int i=0;i<NUMBUTTONS;i++)
 pinMode(buttons[i], INPUT);
 // Start the software serial port, to another device
 RS485Serial.begin(9600);   // set the data rate
}//--(end setup )---
 // flag to indicate that a button changed state
 bool fChanged = false;
 // values of buttons
 byte buttonValues = 0;
 // read all buttons and check for change
 for (int i = 0; i < sizeof(buttons); i++)
   byte buttonState = digitalRead(buttons[i]);
   if (buttonState != lastStates[i])
     // update last state
     lastStates[i] = buttonState;
     // indicate that a button changed
     fChanged = true;
     // set flags in button values
     buttonValues |= (1 << i);
 // if a button changed, send the data
 if (fChanged == true)
     RS485Serial.write(buttonValues);
     Serial.print(buttonValues);
serial monitor show 1,2,4,8,16,32,64...etc
so i can only have 8 input? how to send more than that?
SLAVE
Code: [Select]
#define SSerialTxControl 3   //RS485 Direction control
const byte leds[] = { 22, 24, 26, 28, 30, 32, 34, 36, 38 };
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
int byteReceived;
int byteSend;
 for (int cnt = 0; cnt < sizeof(leds); cnt++)
   pinMode(leds[cnt], OUTPUT);
   digitalWrite(leds[cnt], LOW);
 Serial.println("SerialRemote");  // Can be ignored
 pinMode(SSerialTxControl, OUTPUT);
 digitalWrite(SSerialTxControl, RS485Receive);  // Init Transceiver
 RS485Serial.begin(4800);   // set the data rate
void loop(){
 if(RS485Serial.available())
   byte b = RS485Serial.read();
   Serial.print(b, DEC);
   // loop through the bits in the received byte for every defined LED
     digitalWrite(leds[cnt], b & (1 << cnt));
The LED sometime stay light on sometime light off not responsive
Just beginner here sorry to cause any inconvenience
Moderator edit:
[code]
[/code]
tags added.
