Topic: Which terminals? (Read 1 time) previous topic - next topic
brunokc
Hi
I'm looking for some terminals that I can fit into a box with Arduino inside.
I'm looking 10pin connector male/female for a cabel
and I'm looking 2pin screw connector
I've have searched AliExpress, but without success.
Hope you can help.
Bruno / Denmark
spycatcher2k
Try :
RS Components
Mouser
Digikey
Farnell
Thousands of connectors.  :)
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
brunokc
I've looked at a lot, but I can not find some who looks like that good to mount on the outside of a box.
I thought of something as RJ45 10 pin, but there must be some that are better.
pert
How about putting a 2x5 shrouded male header recessed in the enclosure and a 2x5 female IDC connector on a ribbon cable? It can be a bit difficult to remove so might not be ideal if it's something that will be constantly plugged/unplugged but on the other hand it is unlikely to come loose. If you use the IDE connectors with strain relief it gives a bit more female connector to grab on to.
I haven't looked for the male headers in a panel mount form but you could design your project and enclosure so that the PCB mount ones are positioned correctly, they have right angle ones also if that works better.
brunokc
I have seen them, but is they easy to mount on a box?
pert
As I said before:
What I mean is that the male header is soldered to a circuit board, this provides the mount. The box has a slot cut out in the shape of the shroud and the circuit board is mounted in the box so that the shroud is correctly aligned with the slot in the box.
There are many other options but I try to use IDC+ribbon cable or dupont for all my cabling needs because they are very standard, cheap, and easy to work with once you have the tools. RJ45 cables are cheap but all the PCB mount jacks I've seen aren't compatible with standard 0.1 inch grid.
brunokc
it dont need to fit the uno bord, i will take a wire from the uno to the terminals.
pert
There should be many options to meet your needs on the sites that spycatcher2k recommended. I know that digikey and mouser have a very good parametric search where you can specify the mounting type, number of connectors, termination style, and allow you to sort the results.
jessicota
Hi!!!! you can checking this web:
http://www.pulsatek.com/es/
