Topic: 'HX8357B' (3.2 TFT Monitor) was not declared in this scope (Read 1 time) previous topic - next topic
wbbb1
I bought a 3.2 TFT LCD Monitor off Ebay, when I run the code provided, I get the message 'HX8357B' was not declared in this scope. When I looked inside of UTFT.h file the HX8357B is not listed. When I change the it to HX8347A it get 'Error complining for board Arduino Mega or Mega 2560, the board I am using.
Here is the code (As coped)
#if defined(__AVR__)
   #define imagedatatype  unsigned int
#elif defined(__PIC32MX__)
   #define imagedatatype  unsigned short
#elif defined(__arm__)
#endif
// End of multi-architecture block
#include <UTFT.h>
#include <UTouch.h>
#include <UTFT_Buttons.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
// Declare which bitmaps we will be using
extern imagedatatype cat[];
extern imagedatatype dog[];
extern imagedatatype bird[];
extern imagedatatype monkey[];
// Set up UTFT...
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT   myGLCD(HX8347A,38,39,40,41);
// Set up UTouch...
// Standard Arduino Mega/Due shield            : 6,5,4,3,2
UTouch  myTouch(52, 48, 51,50, 49);
spycatcher2k
OK - a link to the ebay page would be the MINIMUM I would expect for someone asking about it, Posting the whole code correctly would be expected, not just a random part of it, posted incorrectly.
Resolve these and I'll gladly take a look.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
pert
That's why it's not declared, there's nothing that can be done about that error other than modifying the library to support HX8357B or finding a library that already supports it but worth a try with the HX8347A setting:
You need to post the full error output that's in the black console window if you want any help with that(and the full sketch as spycatcher2k requested). There is a button Copy Error Message shown on the right side of the orange bar after you get the error. Click that button and then paste it in a message here using code tags(</> button on the toolbar).
