Topic: Can not receive CAN DATA from Arduino UNO with MCP2515 Module. (Read 46484 times) previous topic - next topic
oasis
I'm trying to receive CAN DATA from Arduino UNO with MCP2515 Module.
I'm not using CAN-BUS Shield and am only using MCP2515 Module(MCP2515 CAN Controller with TJA1050 CAN transceiver. (Attachment #2))
http://www.aliexpress.com/item/MCP2515-CAN-Bus-Module-Board-TJA1050-Receiver-SPI-For-51-MCU-ARM-Controller-NEW/32581650373.html?spm=2114.01010208.8.8.aabjPj
I think that even though I do not use CAN-BUS Shield, I should be able to receive CAN DATA through the MCP2515 module because it includes MCP2515 CAN controller and TJA1050 CAN transceiver.. Is it right?
Here is my test environments:
1) Arduino setting: Attachment #1
OBD2 16pin cable => 6pin(CAN HIGH) and 14pin(CAN LOW) => MCP2515 CAN Module => Arduino UNO
2) CAN Module: Attachment #2
3) Vehicle : VW Tiguan
I connected several pins between with Arduino and MCP2515 module like below:
Arduino     MPC2515 module
5V            VCC
GND         GND
13            SCK
12            SO
11            SI
10            CS
2              INT
I downloaded MCP_CAN_LIB source files.
https://github.com/coryjfowler/MCP_CAN_lib
And I opened a "receive" example of MCP_CAN_LIB from Arduino IDE and initialized like "CAN0.begin(CAN_500KBPS, MCP_8MHz)" because my chinese clone MCP2515 moudule is using 8 Mhz crystal.
But I could not receive any CAN DATA.
The function "digitalRead(2)" always returns HIGH..
Has anyone got this problem?
Code: [Select]
// demo: CAN-BUS Shield, receive data
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
MCP_CAN CAN0(10);                               // Set CS to pin 10
  CAN0.begin(CAN_500KBPS, MCP_8MHz);                       // init can bus : baudrate = 500k
  pinMode(2, INPUT);                            // Setting pin 2 for /INT input
  Serial.println("MCP2515 Library Receive Example...");
    if(!digitalRead(2))                         // If pin 2 is low, read receive buffer
      CAN0.readMsgBuf(&len, rxBuf);              // Read data: len = data length, buf = data byte(s)
      rxId = CAN0.getCanId();                    // Get message ID
      Serial.print("ID: ");
      Serial.print(rxId, HEX);
      Serial.print("  Data: ");
      for(int i = 0; i<len; i++)                // Print each byte of the data
        if(rxBuf[i] < 0x10)                     // If data byte is less than 0x10, add a leading zero
          Serial.print("0");
        Serial.print(rxBuf[i], HEX);
        Serial.print(" ");
robwlakes
Hi Oasis,
I am about to try a very similar set up with a 2007 VW Polo.  (I also own a Tiguan TDI  :) ).
Have you made any progress?  Your request for assistance does not appear to have been heard?
I have ordered the same MCP2515 board and I have a spare Arduino Micro-Pro that I hope to be able to capture events on the car network to make my Car Radio more automatic.  EG turn off when key removed, dim screen when headlights are on. I am not looking to sample any other data at this stage.
My Polo radio connection has the 2 +-CAN-Bus wires in the loom so I am hoping to be able to tap into them.
Perhaps we can work together? Thank you for information above.  I will use it to get started myself.
Cheers, Rob
Learning Flute and C++, heading for a meltdown.
coryjfowler
The code should work with a MCP2510, MCP2515, and an MCP25625, but I have only confirmed it on the latter two ICs.  Additionally, I have tested the library with that very module you linked to and recently infact.
When you tried the receive example, did you have it connected to the vehicle with the key-switch ON (engine OFF)?
"Taking the time to make a proper, punctuated, post is a mark of courtesy and respect."  http://forum.arduino.cc/index.php?topic=149022.0
RickyManfred
Hi Cory
Im trying to use your library to fetch data from a steering angle sensor, data bus it's on is running at 615.3846153846154 Kbit. I tried to modify your library like this;
mcp_can_dfs.h
#define MCP_16MHz_615kBPS_CFG1 (0x00)
#define MCP_16MHz_615kBPS_CFG2 (0xA4)
#define MCP_16MHz_615kBPS_CFG3 (0x01)
My shield is running at 16Mhz and I calculated those values using the spreadsheet included with your library, with BRP set to 0 i get a Time Quantum Max of 13, but I'm not sure I understand it all completely so right now my calculations are pure guesswork.
I tried it in car using the example CAN_recive but with my 615Kbit mod, only result i had was that I managed to get all sorts of warnings on on the cars dashboard when I had the Arduino powered on :)
//Fredrik
coryjfowler
Fredrik,
It looks good on my end with your sample point being at 84.62%.  The only two items I would change is setting the Sample Mode (SAM) bit to change the bit sampling from one sample to three averaged samples, and increase the Synchronization Jump Width (SJW) to 2, these will only help increase reliability but most likely wont fix your issue.  Outside of this, are you positive this is the baudrate and are you positive you have CAN_H and CAN_L correct (reverse them if not)?
The register modifications I mentioned would look like:
Code: [Select]
#define MCP_16MHz_615kBPS_CFG1 (0x80)
#define MCP_16MHz_615kBPS_CFG2 (0xE4)
RickyManfred
Cory, thanks for helping out.
The CAN-bus I'm connecting to is the one found on Saab Trionic 5 and 7 engine management systems. It's quite well documented here: http://www.trionictuning.com.
People active on that forum have written software to communicate with those ECU's over CAN and this is where I found the 615... kbps value. I need this to get the steering angle signal and convert it to an analog signal understandable by a Siemens ECU controlling an AWD system.
/Fredrik
reynard80
I have the same setup (Arduino Uno -> MCP2515 -> TJA1050 -> ODB22 pin 6 and 14), and trouble receiving messages from my Peugeot 207.
Connection from the Arduino to the MCP2515 seems to be just fine, but I'm just not receiving any messages. Now I see the register modifactions mentioned here, but I don't really understand them. Could those also be my problem? Do I need to modify the library as well?
coryjfowler
Are you positive this vehicle has CAN?  The best way to tell is whether there is a physical contact for pins 6 and 14 on the OBDII port of the vehicle.
What baud rates have you tried?  FYI, 250k & 500k are OBDII standards.
Does the board you have come terminated? Remove it if so!  OBDII does not allow a scan tool to have a DC termination.  Also, keep in mind the cable length shouldn't be any longer than 1 meter.
Have you tried swapping the CAN connections going to your the OBDII port?  Eg, the polarity is wrong: CAN_H and CAN_L are reversed and this condition needs corrected.
reynard80
Yes, I'm sure. It is a 2008 car and it's mentioned in different specs. Furthermore, some people have been able to hack into the CAN bus for this vehicle, as can ben seen on Youtube (unfortunately they don't respond to my messages for more information).
Quote from: coryjfowler
Yes, I have tried both.
The board has a jumper to terminate the connection. I've used the board unterminated. See these schematics.
I have tried, but it actually made the instruments go crazy etc, and I got various diagnostic errors on my dashboard (which disappeared after running the car for a while).
coryjfowler
Have you tried sending an OBD-II PID request?  I'd try at 250k first.   It could just be that the port has a CAN bus dedicated for OBD-II and nothing is broadcast over it.  Outside of that I would investigate your hardware.  The fact that reversing the polarity caused an issue tells me the port is active in some sense.
reynard80
That could very well be possible. I haven't tried sending an ODB-II PID. Forgive me if it's a stupid question, but how do I do this with the Arduino and MCP2515? I'm only familiar with sending serial commands via an ELM327.
coryjfowler
You can give this a whirl, it will probably be the weekend before I can load it on one of my boards and throw it at my car.
Code: [Select]
/* CAN OBD & UDS Simple PID Request
 *  Currently requests PID 0x00 at a 1 second interval and
 *  displays all received CAN traffic to the terminal at 115200.
 *  Written By: Cory J. Fowler  April 5th, 2017
 *  (Disclaimer: Standard IDs are currently UNTESTED against a vehicle)
#include <SPI.h>
#define standard 0
// 7E0/8 = Engine ECM
// 7E1/9 = Transmission ECM
#if standard == 1
  #define LISTEN_ID 0x7EA
  #define REPLY_ID 0x7E0
  #define FUNCTIONAL_ID 0x7DF
#else
  #define LISTEN_ID 0x98DAF101
  #define REPLY_ID 0x98DA01F1
  #define FUNCTIONAL_ID 0x98DB33F1
#endif
// CAN TX Variables
unsigned long prevTx = 0;
unsigned int invlTx = 1000;
byte txData[] = {0x02,0x01,0x00,0x55,0x55,0x55,0x55,0x55};
// CAN RX Variables
unsigned long rxID;
byte dlc;
byte rxBuf[8];
char msgString[128];                        // Array to store serial string
// CAN Interrupt and Chip Select Pins
#define CAN0_INT 2                              /* Set INT to pin 2 (This rarely changes)   */
MCP_CAN CAN0(9);                                /* Set CS to pin 9 (Old shields use pin 10) */
void setup(){
  while(!Serial);
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_STDEXT, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
    Serial.println("MCP2515 Initialized Successfully!");
  else{
    Serial.println("Error Initializing MCP2515... Permanent failure!  Check your code & connections");
    while(1);
//  // Allow all Standard IDs
//  CAN0.init_Mask(0,0x00000000);                // Init first mask...
//  CAN0.init_Filt(0,0x00000000);                // Init first filter...
//  CAN0.init_Filt(1,0x00000000);                // Init second filter...
//  // Allow all Extended IDs
//  CAN0.init_Mask(1,0x80000000);                // Init second mask...
//  CAN0.init_Filt(2,0x80000000);                // Init third filter...
//  CAN0.init_Filt(3,0x80000000);                // Init fouth filter...
//  CAN0.init_Filt(4,0x80000000);                // Init fifth filter...
//  CAN0.init_Filt(5,0x80000000);                // Init sixth filter...
#if standard == 1
  // Standard ID Filters
  CAN0.init_Mask(0,0x7F00000);                // Init first mask...
  CAN0.init_Filt(0,0x7DF0000);                // Init first filter...
  CAN0.init_Filt(1,0x7E10000);                // Init second filter...
  CAN0.init_Mask(1,0x7F00000);                // Init second mask...
  CAN0.init_Filt(2,0x7DF0000);                // Init third filter...
  CAN0.init_Filt(3,0x7E10000);                // Init fouth filter...
  CAN0.init_Filt(4,0x7DF0000);                // Init fifth filter...
  CAN0.init_Filt(5,0x7E10000);                // Init sixth filter...
#else
  // Extended ID Filters
  CAN0.init_Mask(0,0x90FF0000);                // Init first mask...
  CAN0.init_Filt(0,0x90DA0000);                // Init first filter...
  CAN0.init_Filt(1,0x90DB0000);                // Init second filter...
  CAN0.init_Mask(1,0x90FF0000);                // Init second mask...
  CAN0.init_Filt(2,0x90DA0000);                // Init third filter...
  CAN0.init_Filt(3,0x90DB0000);                // Init fouth filter...
  CAN0.init_Filt(4,0x90DA0000);                // Init fifth filter...
  CAN0.init_Filt(5,0x90DB0000);                // Init sixth filter...
#endif
  CAN0.setMode(MCP_NORMAL);                      // Set operation mode to normal so the MCP2515 sends acks to received data.
  // Having problems?  ======================================================
  // If you are not receiving any messages, uncomment the setMode line below
  // to test the wiring between the Ardunio and the protocol controller.
  // The message that this sketch sends should be instantly received.
  //CAN0.setMode(MCP_LOOPBACK);
  pinMode(CAN0_INT, INPUT);                          // Configuring pin for /INT input
  Serial.println("Simple CAN OBD-II PID Request");
void loop(){
  if(!digitalRead(CAN0_INT)){                         // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxID, &dlc, rxBuf);             // Get CAN data
    // Display received CAN data as we receive it.
    if((rxID & 0x80000000) == 0x80000000)     // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (rxID & 0x1FFFFFFF), dlc);
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", rxID, dlc);
    Serial.print(msgString);
    if((rxID & 0x40000000) == 0x40000000){    // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
      for(byte i = 0; i<dlc; i++){
        sprintf(msgString, " 0x%.2X", rxBuf[i]);
  /* Every 1000ms (One Second) send a request for PID 00           *
   * This PID responds back with 4 data bytes indicating the PIDs  *
   * between 0x01 and 0x20 that are supported by the vehicle.      */
  if((millis() - prevTx) >= invlTx){
    prevTx = millis();
    if(CAN0.sendMsgBuf(FUNCTIONAL_ID, 8, txData) == CAN_OK){
      Serial.println("Message Sent Successfully!");
      Serial.println("Error Sending Message...");
Edit 20170514: Tested and fixed some bugs.  I can confirm that extended ID mode (#define standard 0) works with my vehicle and I unfortunately do not have access to a vehicle that operates in standard ID mode to confirm with.
reynard80
Thanks a lot. I've tried your code (just changed 16MHz -> 8MHz, INT on pin 9 -> pin 10).
However, I'm not getting any output other than just the setup of the module. My knowledge in this field is very limited, but could the 8MHz crystal be the problem? Maybe some of the values in the timing registers for 8MHz?
Code: [Select]
Entering Configuration Mode Successful!
Setting Baudrate Successful!
Starting to Set Mask!
Setting Mask Successful!
Starting to Set Filter!
Setting Filter Successfull!
coryjfowler
I have tested some of the more common 8MHz baud rate configuration register settings against a Peak adapter and a Vector VN1610, so I trust those to be good.
I edited the send function to give some indication about when a message was sent or if there was an error while sending.  If there is no error while sending and your car doesn't exhibit any signs we are corrupting signals (like when the CAN line polarity was reversed), it should be safe to assume the baudrate of 250k is correct.  In that case, try changing the 1 in "#define standard 1" to a 0 to try OBD-II with extended IDs.  Otherwise, try it again, but only changing the baudrate to 500k.
If you get send errors at both 250k and 500k, change "CAN0.setMode(MCP_NORMAL);" to "CAN0.setMode(MCP_LOOPBACK);".  You should see the one packet we transmit come right back and display on the screen.  This will confirm your protocol controller is functioning as it should and that it is correctly wired to the Arduino.
If you do not see a received message, check your INT pin connection and the definition for it in the sketch.
If you see the received message while in loop back, I would check the connection between the protocol controller and the transceiver making sure that there is continuity between the ICs and that there are not shorts to ground, power, or another signal.
reynard80
Ok, it was just a thought, because 16MHz seem to be 'standard'.
I got the error message, both with 250k and 500k. I got the error message both when connected to the car, and when not connected to a CAN bus at all.
I measured the voltage with a multimeter on the ODBII port in the car, and when not connected to my project, the voltages are DC 2.56V both on H and L.
I actually see the received message in loopback, so that seems to work. I have also checked the PCB for continuity between the MCP2515 and the TJA1050. Also, the VCC and GND connections seem to be working properly. I'm wondering however if maybe the VCC for the transceiver chip is too low, as I'm measuring 4.01V over the VCC and GND. The datasheet says 4.75V minimum. But maybe it is just normal to measure a lower voltage when the IC is running?
