Topic: First code (Read 4925 times) previous topic - next topic
Morke
The INPUT_PULLUP functionality is activated by writing a HIGH to the output register.
So the Arduino output will start with a HIGH level, which is the relay off state.
Oh, ok, so, the code uses INPUT_PULLUP to turn off all the relays the first time it runs, and then sets them as OUTPUT
It's like using digitalwrite(relay, HIGH) ?
What, a zoologist????
Whandall
It writes to the port like digitalWrite() does.
Code: [Select]
void pinMode(uint8_t pin, uint8_t mode)
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
volatile uint8_t *reg, *out;
if (port == NOT_A_PIN) return;
// JWS: can I let the optimizer do this?
reg = portModeRegister(port);
out = portOutputRegister(port);
if (mode == INPUT) {
uint8_t oldSREG = SREG;
                cli();
*reg &= ~bit;
*out &= ~bit;
SREG = oldSREG;
} else if (mode == INPUT_PULLUP) {
                cli();
*reg &= ~bit;
*out |= bit;
SREG = oldSREG;
                cli();
*reg |= bit;
SREG = oldSREG;
Code: [Select]
void digitalWrite(uint8_t pin, uint8_t val)
uint8_t timer = digitalPinToTimer(pin);
volatile uint8_t *out;
// If the pin that support PWM output, we need to turn it off
// before doing a digital write.
if (timer != NOT_ON_TIMER) turnOffPWM(timer);
cli();
if (val == LOW) {
*out &= ~bit;
*out |= bit;
SREG = oldSREG;
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
larryd
digitalwrite(relay, HIGH);
Seems a bit more intuitive.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Whandall
Absolutely.
dlloyd
#34
Jun 08, 2016, 02:54 am Last Edit: Jun 08, 2016, 02:54 am by dlloyd
Simply, the two configuration methods described prevent the relay pins from temporarily going LOW prior to entering the main loop. A relay pin temporarily going LOW could cause the relay to temporarily energize during setup.
Using one of the recommended setup methods, the pin does this:
1. Most pins are initially configured as INPUT (high impedance, floating). Relay remains OFF
2. Then the internal pullup gets enabled. The pin is weakly pulled to 5V. Relay remains OFF
3. Then the pin gets configured as OUTPUT. The pin is driven to 5V (the new default). Relay remains OFF
Now all relays are under your control in the main loop.
Morke
Ok so verifying the code this error pops up
Code: [Select]
Arduino: 1.6.8 (Windows 7), Board: "Arduino/Genuino Uno"
 In function 'void setup()':
temprelayfinal2:42: error: a function-definition is not allowed here before '{' token
temprelayfinal2:75: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
And it shows a red line here:
Code: [Select]
[color=red]{[/color]
  analogReference(INTERNAL);
  for (int i = 0; i < 4; i++) {
    pinMode(relayPin[i], INPUT_PULLUP);
    pinMode(relayPin[i], OUTPUT); // defaults HIGH, relay OFF
Whandall
And the code above the failing definition of setup() has the error.
Morke
nvm i found the error
Morke
Would it be possible to add an array to make the relays work on Avg temperatures to smooth the readings?
dlloyd
#39
Jun 08, 2016, 03:48 am Last Edit: Jun 08, 2016, 04:14 am by dlloyd
Averaging might not be needed. Try adding an extra reading so there's 2 readings in a row. The first will be overwritten. The second will be more accurate because there's been a bit more time for the ADC value to settle.
Code: [Select]
reading[i] = analogRead(tempPin[i]);
EDIT: added above and some simple averaging for readings in code in reply#27.
Morke
#40
Jun 08, 2016, 03:42 pm Last Edit: Jun 08, 2016, 04:14 pm by Morke
So I'm trying to add an average to smooth things out and to practice coding.
Could you correct the code? i'm sure it's wrong, but I want to know why.
Thank you
Code: [Select]
const byte tempPin[] = {A1, A2, A3, A4};
const byte relayPin[] = {6, 7, 8, 9};
// hysteresis = upperLimit - lowerLimit
const byte lowerLimit = 24;
const byte upperLimit = 31;
float tempC[4];
word reading[4];
const int numReadings = 50; //added
int readings[numReadings];                  //added
int readIndex = 0;                              //added
int total = 0;                                     //added
int average[4] = 0;[/color]                  //addded
word printInterval = 1000; // 1 second
unsigned long printCheck = 0, lastPrintTime = 0;
 for (int thisReading = 0; thisReading < numReadings; thisReading++){ //added
    readings[thisReading] = 0;                                                        //added
  // readings and control
    tempC[i] = reading[i] / 9.31;
    total[i] = total[i] - readings[readIndex];  //added
    readings[readIndex] = tempC[i]                            //added
    total[i] = total[i] + readings[readIndex]                 //added
    readIndex[i] = readIndex[i] + 1 ;                          //added
    if (readIntex[i] >= numReadings) {                        //added
    average[i] = total[i] / numReadings;[/color]           //added
    if (average[i]< lowerLimit) {
      digitalWrite(relayPin[i], LOW);   //relay OFF
    else if (average[i] > upperLimit) {
      digitalWrite(relayPin[i], HIGH);  // relay ON
  printCheck = millis() - lastPrintTime;
  if (printCheck >= printInterval) {
      Serial.print("TempC");
      Serial.print(i + 1);
      Serial.print(" ");
      Serial.println(average[i]);
    lastPrintTime = millis(); // reset print timer
PaulS
Does your code really have [ color=red ] crap in it?
Morke
#42
Jun 08, 2016, 04:39 pm Last Edit: Jun 08, 2016, 05:05 pm by Morke
Nah, I tried to highmark the changes and forgot to delete the bb code afterwards. Sorry
Morke
Ok, a guy made it A LOT SIMPLER using Exponential smoothing:
Code: [Select]
const int numReadings = 64;
const word printInterval = 1000; // 1 second
float tempC[4];
unsigned long lastPrintTime = 0;
    float raw_temp = analogRead(tempPin[i]) / 9.31;
    tempC[i] += (raw_temp - tempC[i]) / numReadings;  // filter
    if (tempC[i] < lowerLimit) {
    else if (tempC[i] > upperLimit) {
  if (millis() - lastPrintTime >= printInterval) {
      Serial.print("tempC");
      Serial.print(" ");
      Serial.println(tempC[i]);
