Topic: Use both GSM_SMS and GSMVoiceCall (Read 1 time) previous topic - next topic
jayel
Hello,
My code :
Quote
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
//GSM_SMS sms;
GSMVoiceCall vcs;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
// Array to hold the number for the incoming call
char numtel[20];
 // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("gsmserver|message|SERIAL READY");
   // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while (notConnected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      notConnected = false;
      Serial.println("gsmserver|message|GSM MODEM NOT CONNECTING");
   // This makes sure the modem correctly reports incoming events
  vcs.hangCall();
  Serial.println("gsmserver|message|GSM SERVER READY");
   // Check the status of the voice call
  char c;
  switch (vcs.getvoiceCallStatus()) {
    case IDLE_CALL: // Nothing is happening
    case RECEIVINGCALL: // Yes! Someone is calling us
     // Serial.println("RECEIVING CALL");
      // Retrieve the calling number
      vcs.retrieveCallingNumber(numtel, 20);
      // Print the calling number
      Serial.print("gsmserver|command|receivecall|");
      Serial.println(numtel);
      // Answer the call, establish the call
     // vcs.answerCall();
    case TALKING:  // In this case the call would be established
      Serial.println("TALKING. Press enter to hang up.");
      while (Serial.read() != '\n') {
        delay(100);
      vcs.hangCall();
      Serial.println("Hanging up and waiting for the next call.");
   // If there are any SMSs available()
  if (sms.available()) {
    Serial.print("gsmserver|command|receivesms|");
    // Get remote number
    sms.remoteNumber(senderNumber, 20);
    Serial.print(senderNumber);
    Serial.print("|");
    // An example of message disposal
    // Any messages starting with # should be discarded
    if (sms.peek() == '#') {
      Serial.println("Discarded SMS");
      sms.flush();
    // Read message bytes and print them
    while (c = sms.read()) {
      Serial.print(c);
    Serial.println("");
    // Delete message from modem memory
    sms.flush();
    //Serial.println("MESSAGE DELETED");
It is a combination of the recievecall and recievesms example.
When I use both GSM_SMS and GSM_voicecall classes, the program doens't show GSM SERVER READY.
When i command out GSM_SMS and command out the functions from the sms (like example here on top) then it workes?
It seems like I can't receive calls and receive sms at the same time?
Somebody who can help?
Greets John
jayel
Hey,
Nobody?
Strange that nobody who has bought the arduino GSM shield, never used sms and voicecall on the same arduino?
Greets
John
jayel
these classes were made by you (arduino), strange that nobody can help me with this problem.
greets John
SupArdu
hi,
I am using both VoiceCall and SMS but a little bit differently:
Code: [Select]
switch (vcs.getvoiceCallStatus()) // IDLE_CALL, CALLING, RECEIVINGCALL, TALKING
      // Check if there are any SMSs available()
      Serial.println("IDLE_CALL ----->sms.available()");
        Serial.println("Message received from:");
        ...    // here processing SMS
Cecking if SMS is available and processing is located in "case IDLE_CALL".
I don't know if this is the essential difference, but it works.
I would expect that your code also is working, but  :smiley-confuse:
SupArdu
have success
SupArdu
