Topic: Beginner Electronics (Read 6241 times) previous topic - next topic
raschemmel
Of course if you have absolutely made up your mind you want to learn electronics you could just go nuts and order this:
earthlinginspace
Whats wrong with raschemmel?
I've looked online and found a course that MIT did back in 2012.
Here's the link:
https://6002x.mitx.mit.edu/courseware/6.002_Spring_2012/Week_1/Resistor_Divider/
I might follow that and learn something along the way!
raschemmel
#17
May 25, 2016, 02:21 pm Last Edit: May 25, 2016, 06:11 pm by raschemmel
Quote
Only you can answer that question for yourself. Everyone has their own opinion. It is up to you to find the truth by reading a member's posts.
The forum provides a way for you to do that:
Click on the member's name just above their Avatar.
You will see the following Links:
Send PM
Show Posts
Show Stats
Click on "Show Posts"
You will be taken to a page that shows a numbered list of that member's posts.
At the top of the screen you will see a message in small print that says this:
Quote
This section allows you to view all posts made by this member. Note that you can only see posts made in areas you currently have access to.
On the left side of the screen you will see a small label that says "Page [1]" , indicating you are on page 1 of a reverse numbered list ("1 being latest (newest)  page and the last number being OLDEST page".
The post numbers on the left are also in a chronollogically reverse list with "1" being latest (newest) post and the last number being the oldest post.
When reading a member's post you must follow certain judging rules established by order of priority since there is more there (in the post) than meets the eye. On the face of it , you see a comment , but if you read the content of the comment and think about it, you will see that some comments are addressing the OP's (Original Poster's) behavior and methods, rather than the OP's actions.
For example:
an OP posts for help with an LED. (no schematic is given, no code is posted)
As you read the replies of the members responding to the posts, it becomes evident that the OP is ignoring many replies and not responding to each one in turn. He/she is picking and choosing which replies to respond to. Keep in mind that the member's replying to the post , whether they admit it or not , are competing for the OP's karma clicks .(occasionally it becomes necessary to actual TELL the OP HOW to thank responding members by explaining the karma click mechanism, because some members (one was from Russia) think that the karma click mechanism is a NEGATIVE tool used to indicate you DO NOT LIKE that particular member ("Traditionally, karma is negative" was the explaination for that misunderstanding by the Russian member). The karma click mechanism is a forum tool to THANK a member for being helpful, by clicking on the "Add" button just to the right of that member's karma count. A member's karma count indicates how members have thanked that member for being helpful. Some members (usually ones who don't have a lot of karma), try to play it down as insignificant or irrelevant.
Some member's when challenged by another member will cite their karma count and compare it to the karma count of someone criticizing them with the comment "
"Judging from your karma count , you have been busier criticizing other members than helping other members " or some such comment.  The member's responding to a post are competing for karma counts whether they like it or not because in the end, if the OP's issue is resolved by the comments of one particular member, they will click on that member's karma button to "give them karma". This being the case, some member's will be obsequious and flattering to try to win a karma click by being nice. Other , more experienced and older members, will tell the OP whatever they think , whether it is complementary or not , knowing that the OP is best served by knowing the truth. This will be obvious by comments like "You need to stop fumbling around and start being systematic and take notes" or "research your topic on Google  before posting" or "You need to be more organized and methodical instead of just poking around and relying on trial and error for everything" or "if you spent more time researching your topic you wouldn't be in the situation you're in now" . All of these comments are critical and can be interpreted by the OP as negative or may actually offend or even anger the OP (prompting the OP to "stiff" them by withholding a karma point ). The older more experienced members don't care whether they get the karma click or not because they believe their mission is to help members, not collect karma clicks. I am one of the oldest (if not THE oldest member on the forum) and I fall into that category. There is one member who I believe is older but I will not say who that is.
Often what the OP needs, is not instructions for how to get a LED working but guidance on how to be more efficient and systematic in their approach. Often the "problem" is NOT that the led doesn't work. That is only a symptom. The problem is often the OP is just plain lazy or careless, and won't take the time to read a datasheet or Google their topic , or read every reply posted on their thread. When you see an OP NOT responding to reples that contain technical detail or instructions, it is often because the OP has no clue what that member just said and is too embarrassed to say so. Sometimes it is necessary to tell the OP that they screwed up or that they are careless or lazy etc because ultimately only then can they change their behavior. Otherwise, the led that doesn't work will only be the first of a long list of posts for things that don't work.
Sometimes it is necessary to ignore the led and focus on the OP who are their own worst enemy. Telling them the truth the whole truth and nothing but the truth always comes with the risk of offending the OP. Some members only care about getting the karma click and won't tell the OP what they really need to hear . (I am not one of those. I tell the OP what I think based on what they posted, and how they deal with it is their problem , not mine).As long as what I am telling them is the truth, that's all that matters. I'm not running for office.
I will be the first to admit that I tend to be blunt and occasionally people are offended because they don't like being told they are lazy or careless.
(ie: "if you took 5 seconds to Google "[etc], you would not need to post with this question")
At this point I should mention that 90% of the complaints by "Newbies" about Google not being helpful is due to the fact they have included the word "arduino" at the beginning of their keyword search string.
Google sorts all links about arduino related topics together so if you fail to include the word "arduino" at the beginning of their search string, you will get ALL the links related to the topic and you will have to sift through them to find the arduino related links.
You will notice when reading other members posts that some are always one liners and some are long and detailed. Obviously,the one liners still count as posts and increment their post count so members who typically post one liners will always have a higher post count. Members who post mostly long and detailed posts will tend to have lower post counts. Members with high post counts and high karma counts have either been around a long time or have been very busy and helpful.
You be the judge.
Last but not least, if you want to evaluate another member quickly without spending a lot of time reading their posts, you can click on their name, look at the date they registered, devide their post count by the years elapsed since they registered to obtain their Posts /per year count. Then divide their karma count by the years elapsed since registration to obtain their karma /per year count. You can also divide their karma count by their post count to get their karma per post count (with 1:1 ratio being the highest possible ), which you can then multiply by 100.
xl97: Registered Aug 2009
Years Member: 7
Posts/Year: 230
Karma/Year: 12
Karma/Post *100: 5
pwillard: Register Nov, 2008
Years Member: 8
Posts/Year: 249
Karma/Year: 8.5
Karma/Post *100: 3.45
Note: I added something to Reply#13
Paul__B
raschemmel
Quote
Paragraphs?
that's the best I can do...
earthlinginspace
I never knew this site was so serious, it's great! :D
raschemmel
The average hands on electronics job experience of the senior members is 20 years, and some have as much as 40 + years. (I have 35). Some are still working professionals and many are retired. The total experience of all the top ten senior membors added together is easily > 200 years. The rest of the top 50 senior members have probably 5 to 10 years electronics experience . Everyone else is a non professional (does not work in electronics).
"I never joke about my work Mr. Bond...."
Grumpy_Mike
Quote
As one of the members who have been here for a long time I should point out that Kama points were not always available as an option, then the disappeared for a year or so and are now back. I recon I had about 20,000 posts that it was not possible to click Kama on, so the older members are at a disadvantage here in the Kama / posts ratio.
raschemmel
Really Mike ? With over 1000 karma points you're concerned that you might have been short changed ?
CrossRoads
And there was negative karma for a while too, that was fun, sort of.
raschemmel
I'm glad they got rid of that before I started !
CrossRoads
#26
May 25, 2016, 10:21 pm Last Edit: May 25, 2016, 10:32 pm by CrossRoads
Fun with #s (being an engineer and all):
Years Member: 5.7
Posts/Year: 6336 (posts/day * 365)
Karma/Year: 1302/5.7 = 228.4
Karma/Post *100: 1302/36506 * 100 = 3.57
Buy what  you need for a project, and some extra. 0.1uF caps, 1K & 10K resistors, LEDs, buttons, etc. Take advantage of the low prices and stock up.  I once spent $40 and got a huge bag of stuff, that I am still using in projects. www.taydaelectronics.com and www.dipmicro.com are good, not so many choices that you get overwhelmed by the selection, not pricey, and doesn't take weeks and weeks to arrive from China. Then www.digikey.com and www.mouser.com as you get comfortable looking for specific things, such as an inexpensive, Low Rds, Logic Level gate,  thru hole N-channel MOSFET to control sinking current thru a motor:
http://www.digikey.com/product-search/en?keywords=aoi514
Paul__B
Buy some coin envelopes at the stationary store for catalogging resistors and capacitor and other components:
But you can't see the components inside.
I prefer zip-lock baggies.  The trick is getting small ones rather than sandwich bags.  The eBay sellers seem to have an endless supply of small ones, clearly dirt cheap.
raschemmel
#28
May 26, 2016, 01:05 am Last Edit: May 26, 2016, 01:08 am by raschemmel
I actually did try bags first and I hated them. I like the envelope because they are simi rigid and formless like baggies. I love the way you can slip the 4.7 k resistor envelope between 4.2 k and 5.1 k easily .
I actually like that you can't see the bottles in my carryall..
Paul__B
For the amount that I use, I will settle for sorting by decade.
I have found drawers useless, moving to used Mighty Mite bottles (with labels removed).
