Topic: Installation of RXTX in MAC oOS (Read 409 times) previous topic - next topic
acgsruthi
I am using RXTX library to connect with scratch program. I have a Jar file called A4S which helps to connect the Arduino board with scratch program. I used this RXTX file in Windows it worked fine and the serial communication also happened with out any problem but I need to use RXTX library in Mac os and it seems not to work can you please suggest me as how can i install it or do i have any other supporting Jar file for executing this serial communication in JAVA ( netbeans IDE ). Pls help me solve this issue ?
Robin2
JSSC is the newer Java serial library and should be easier to work with. AFAIK RXTX is no longer maintained.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
