@someone83
Es gibt kein WiFiStart(); for die Setup.
@stoni99
Hierunter die Original Sketch aus den link, hab nur die
const char* ssid = "KKA";
const char* password = "test";
Geändert
HTTP 1.1 Webserver for ESP8266
for ESP8266 adapted Arduino IDE
Stefan Thesen 04/2015
Running stable for days
(in difference to all samples I tried)
Does HTTP 1.1 with defined connection closing.
Reconnects in case of lost WiFi.
Handles empty requests in a defined manner.
Handle requests for non-exisiting pages correctly.
This demo allows to switch two functions:
Function 1 creates serial output and toggels GPIO2
Function 2 just creates serial output.
Serial output can e.g. be used to steer an attached
Arduino, Raspberry etc.
#include <ESP8266WiFi.h>
unsigned long ulReqcount;
unsigned long ulReconncount;
// Create an instance of the server on Port 80
WiFiServer server(80);
// setup globals
ulReqcount=0;
ulReconncount=0;
// prepare GPIO2
pinMode(2, OUTPUT);
digitalWrite(2, 0);
// start serial
delay(1);
// inital connect
WiFi.mode(WIFI_STA);
WiFiStart();
void WiFiStart()
ulReconncount++;
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
// check if WLAN is connected
if (WiFi.status() != WL_CONNECTED)
WiFiStart();
// Check if a client has connected
WiFiClient client = server.available();
if (!client)
return;
// Wait until the client sends some data
Serial.println("new client");
unsigned long ultimeout = millis()+250;
while(!client.available() && (millis()<ultimeout) )
delay(1);
if(millis()>ultimeout)
Serial.println("client connection time-out!");
return;
// Read the first line of the request
String sRequest = client.readStringUntil('\r');
//Serial.println(sRequest);
client.flush();
// stop client, if request is empty
if(sRequest=="")
Serial.println("empty request! - stopping client");
client.stop();
return;
// get path; end of path is either space or ?
// Syntax is e.g. GET /?pin=MOTOR1STOP HTTP/1.1
String sPath="",sParam="", sCmd="";
String sGetstart="GET ";
int iStart,iEndSpace,iEndQuest;
iStart = sRequest.indexOf(sGetstart);
if (iStart>=0)
iStart+=+sGetstart.length();
iEndSpace = sRequest.indexOf(" ",iStart);
iEndQuest = sRequest.indexOf("?",iStart);
// are there parameters?
if(iEndSpace>0)
if(iEndQuest>0)
// there are parameters
sPath = sRequest.substring(iStart,iEndQuest);
sParam = sRequest.substring(iEndQuest,iEndSpace);
// NO parameters
sPath = sRequest.substring(iStart,iEndSpace);
// output parameters to serial, you may connect e.g. an Arduino and react on it
if(sParam.length()>0)
int iEqu=sParam.indexOf("=");
if(iEqu>=0)
sCmd = sParam.substring(iEqu+1,sParam.length());
Serial.println(sCmd);
// format the html response
String sResponse,sHeader;
// 404 for non-matching path
if(sPath!="/")
sResponse="<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server.</p></body></html>";
sHeader = "HTTP/1.1 404 Not found\r\n";
sHeader += "Content-Length: ";
sHeader += sResponse.length();
sHeader += "\r\n";
sHeader += "Content-Type: text/html\r\n";
sHeader += "Connection: close\r\n";
sHeader += "\r\n";
// format the html page
ulReqcount++;
sResponse = "<html><head><title>Demo für ESP8266 Steuerung</title></head><body>";
sResponse += "<font color=\"#000000\"><body bgcolor=\"#d0d0f0\">";
sResponse += "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">";
sResponse += "<h1>Demo für ESP8266 Steuerung</h1>";
sResponse += "Funktion 1 schaltet GPIO2 und erzeugt eine serielle Ausgabe.<BR>";
sResponse += "Funktion 2 erzeugt nur eine serielle Ausgabe.<BR>";
sResponse += "<FONT SIZE=+1>";
sResponse += "<p>Funktion 1 <a href=\"?pin=FUNCTION1ON\"><button>einschalten</button></a> <a href=\"?pin=FUNCTION1OFF\"><button>ausschalten</button></a></p>";
sResponse += "<p>Funktion 2 <a href=\"?pin=FUNCTION2ON\"><button>einschalten</button></a> <a href=\"?pin=FUNCTION2OFF\"><button>ausschalten</button></a></p>";
// react on parameters
if (sCmd.length()>0)
// write received command to html page
sResponse += "Kommando:" + sCmd + "<BR>";
// switch GPIO
if(sCmd.indexOf("FUNCTION1ON")>=0)
digitalWrite(2, 1);
else if(sCmd.indexOf("FUNCTION1OFF")>=0)
digitalWrite(2, 0);
sResponse += "<FONT SIZE=-2>";
sResponse += "<BR>Aufrufzähler=";
sResponse += ulReqcount;
sResponse += " - Verbindungszähler=";
sResponse += ulReconncount;
sResponse += "<BR>";
sResponse += "Stefan Thesen 04/2015<BR>";
sResponse += "</body></html>";
sHeader = "HTTP/1.1 200 OK\r\n";
sHeader += "\r\n";
sHeader += "\r\n";
// Send the response to the client
client.print(sHeader);
client.print(sResponse);
// and stop the client
client.stop();
Serial.println("Client disonnected");
